Thread: KVR big brake kit
Results 1 to 20 of 20
  1. #1 KVR big brake kit
    Looking to get bigger brakes for 00 gt...was looking at the KVR big brake kit..its a lot of money but its the only kit that I see that uses 4 piston calipers. Anybody heard anything about how good it is?
  2. #2 Re: KVR big brake kit
    4 piston calipers? wow.
    i dont have it, but ive heard the f-body upgrade is more than enough to stop these cars.
  3. #3 Re: KVR big brake kit
    I live here. UR LOSN's Avatar
    Rockford, IL
    Baer I believe is 4 piston as well.....but they want mucho denero....
  4. #4 Re: KVR big brake kit
    SE Level Member RED GTX's Avatar
    Quote Originally Posted by UR LOSN View Post
    Dpends which kit you go with. Mine are only 2 pistons; I couldn't imagine having another 2.
  5. #5 Re: KVR big brake kit
    SE Level Member 98GP's Avatar
    North East, OK
    I've got the F-Body brakes, and its definitely more than enough, unless you're just a fatass and keep the car rolling
  6. #6 Re: KVR big brake kit
    Donating Users
    Palatine, IL
    I just wanted to add my two cents to say that you'll be fine with the F-Body brakes with SS lines. I've autocrossed and roadraced with that setup and they work fine.
  7. #7 Re: KVR big brake kit
    what all do you need and what modifactions do you need to get the F-body calpiers to fit?
  8. #8 Re: KVR big brake kit
    Banned
    Wichita Falls, Texas
    F-body Rotors, calipers, brackets, and then tap the holes out that hold the caliper on and your good to go.
  9. #9 Re: KVR big brake kit
    well I need breaks anyway so I guess there's no reason to replace when there are upgrades. can you use the large impala rotors? I already have a set of them. isn't the bolt pattern different for the F-body rotors? I thought it was 5x4.75 and the GP was 5x4.5?
  10. #10 Re: KVR big brake kit
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    W body and F body share rotors. The holes are large enough to fit both bolt patterns.
  11. #11 Re: KVR big brake kit
    ok, so the large impala rotors will work then?
  12. #12 Re: KVR big brake kit
    Barksdale AFB, LA
    Quote Originally Posted by s10mods View Post
    Yes. Impala/Monte rotors are the same as the F-body rotors.
    2009 Subaru Impreza WRX STI
  13. #13 Re: KVR big brake kit
    TDCRacing
    Guest
    will f-body brakes work with stock wheels?
  14. #14 Re: KVR big brake kit
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    Should. Several Impala owners run with F-body brakes and stock 16" wheels. The 13" rotor upgrade requires larger rims, not the F-body (which uses a 12" rotor) upgrade.
  15. #15 Re: KVR big brake kit
    Greensburg, PA
    hey if you're running 17" or larger rotors year round i have a set of GXP front calipers brackets rotors and pads. im selling. Its a 12.7" rotor with a dual piston caliper. Bolt straight up so no modification needed. all youd need to get is new lines.
    Mods:3.4 pulley + recommended mods/ F-Body Front & rear GXP Calipers/ GMPP handling upgrade kit + otto strut brace/ SSC Gen 1 Springs on GR-2 struts/ Verde 5 18x8 Rims
  16. #16 Re: KVR big brake kit
    TDCRacing
    Guest
    17'' or larger wheels you mean? how much?
  17. #17 Re: KVR big brake kit
    Greensburg, PA
    hahah yea i did mean wheels. my bad. I'm selling it for 200 plus shipping. Its in the for sale section of this forum.
  18. #18 Re: KVR big brake kit
    TDCRacing
    Guest
    if i only had 17's
  19. #19 Re: KVR big brake kit
    Greensburg, PA
    Thats what everyone says lol. I wish i wasn't in an area where it snowed cuz id be running my 18's year round and have this upgrade on my car. o well
  1. 12" brake questions
    By FASGP in forum Brakes/Suspension/Chassis
    Last Post: 01-14-2008, 05:59 PM
  2. LS1 brake question
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2008, 12:14 PM
