Thread: Replaced Calipers
Results 1 to 17 of 17
  1. #1 Replaced Calipers
    Aug 2013
    arlington, tx
    Hey guys, quick question. I replaced the front calipers on my 04 on Saturday. Did I need to bleed all 4 calipers or just the front ones? I bled the passenger side first and then did the driver side and the brakes feel good and better than before but just wanted to get that doubt out of my mind. It was pretty straight forward and easy changing them out. There was no torque specs for the bolt on the brake line right? I just tightened it pretty good and checked for leaks after turning the car on and having someone pumping the brakes. The old passenger caliper wouldn't even go back enough to slide over the new brake pads no matter how hard I pushed that piston in. The bushing around the piston was torn and broken and I just replaced both since I figured the other side might be on its way out too. Got the reman ones at autozone being that they were warrantied for lifetime plus I work there and get 30% off. Haha.
  2. #2 Re: Replaced Calipers
    Technically, you should bleed all four corners, starting with the RR, LR, RF then LF
  3. #3 Re: Replaced Calipers
    your ok just bleeding the fronts.
  4. #4 Re: Replaced Calipers
    Aug 2013
    arlington, tx
    Well I do need to do a flush on the brake fluid but I was running low on time and just wanted to finish already cuz I had to go pick up my daughter already. And basically bleed the system starting with the caliper furthest away from the reservoir and work my way down right?
  5. #5 Re: Replaced Calipers
    yup. like bill said.
  6. #6 Re: Replaced Calipers
    And to back Scott up further.. technically if the master cylinder doesn't go dry ..then you shouldn't need to bleed all four. However it's common and good practice to ensure the best braking possible.
  7. #7 Re: Replaced Calipers
    Aug 2013
    arlington, tx
    Yea I kept an eye on the reservoir while bleeding and made sure it didn't go dry. Now i'm the type that likes to know why things work the way they do instead of just how they should work. So with that being said, why do you have to bleed the brakes in that certain order? Are all the brake lines eventually tied in together at a certain point and that comes into play or what?
  8. #8 Re: Replaced Calipers
    like bill said. ^^^
  9. #9 Re: Replaced Calipers
    back and front brakes are separate. ( unless the master goes dry, then they all "need" to be bleed, along with the master) but always start at the furthest away wheel.
  10. #10 Re: Replaced Calipers
    Aug 2013
    arlington, tx
    Scottydoggs, I read that and understand there is a certain order but I'm asking WHY is there a certain order?
  11. #11 Re: Replaced Calipers
    Aug 2013
    arlington, tx
    Ok. Got it, thanks.
  12. #12 Re: Replaced Calipers
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Quote Originally Posted by luckyg817 View Post
    The order bill posted basically has you bleed the "furthest" caliper from the master cylinder first, then the 2nd furthest, 3rd, 4th.... you get the idea. The goal is to bleed the longest line first so that you dont have bubbles from the longer lines "unbleed" your shorter lines.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  13. #13 Re: Replaced Calipers
    Aug 2013
    arlington, tx
    Tcboltfawker, thanks for the explanation. That's what I was looking for. So all the brake lines do tie in at a certain point then?
  14. #14 Re: Replaced Calipers
    yes and not really lol theres a lot going on, master to the abs pump is just front and rear, from there its a line to each wheel.
    some older cars tho, split the rear brake line so both backs used the one line back to them. so thats where the old rr, lr, rf, lf all started from i guess.
  15. #15 Re: Replaced Calipers
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Correct me if I'm wrong, but I thought I read somewhere that bleed order doesn't matter if you have an ABS module.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  16. #16 Re: Replaced Calipers
    in the end i bet it really dont matter much, but the old rules always say LR, RR, THEN THE RF ,LF.
  17. #17 Re: Replaced Calipers
    Really.. it comes from the FSM (factory service manual) without any good info as to why,
    On my pickup though.. with only one rear line, it gets the air to the furthest line..then each after that is closer and faster/easier to bleed the air from.
  1. CTS v calipers????
    By sandobar in forum Brakes/Suspension/Chassis
    Last Post: 04-26-2012, 09:14 AM
  2. C5 Calipers
    By Suaveat69 in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2010, 09:59 PM
  3. C5 calipers how much would you pay for?
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 09-05-2008, 05:43 PM
