Thread: 12" brake questions
Results 1 to 10 of 10
  1. #1 12" brake questions
    SE Level Member FASGP's Avatar
    Toronto ON
    First...12" Monte rotors from 2002 are 5x118. Is there a better solution with the proper 5x115 pattern for a better fit?
    Second, would the 2002 Monte wheel hubs be compatable with our cars?
    TIA.
    Vtec...All the lag and none the turbo...it's like waiting for bad sex
  2. #2 Re: 12" brake questions
    SE Level Member oneswt00gtp's Avatar
    Angier, NC
    Use The Rotors Off An Intruige (sp) With Hd Brakes That Is What I Did Then I Bought Loaded Calipers For A Ss Camaro And You Need An Aluminum Banjo Bolt For Each Caliper (junkyard Freebee) It All Cost Me Like $100-$150 For Everything From Carquest
  3. #3 Re: 12" brake questions
    GT Level Member 7801MonteMan's Avatar
    S.E Michigan
    Rotors from a 02 Monte are NOT 5x118. There same bolt pattern as any other late model wbody.
    ASE Certified and I-Car Auto Refinishing Paint Technician
    -78 Monte Carlo -01 Monte Carlo LSX
  4. #4 Re: 12" brake questions
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    GM made those rotors to fit the f-body and w/h-body bolt patterns
  5. #5 Re: 12" brake questions
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    yeh. the bolt patern holes are enlarged to fit mulltiple applications....
  6. #6 Re: 12" brake questions
    chicago
    bolt pattern from 00-05 mc should be the same as the all the late wbody like 7801monteman said.
  7. #7 Re: 12" brake questions
    Toronto ON
    Ok, well they clearly list them as 5x118 when ordered. If they are all the same, then so be it.
    Can someone shed light to me why no matter what I have done, they squeal like hell when heated up? New pads twice once ceramic, new rotors twice, new calipers and brackets now. Still. Sure, they brake really well, but they sound like ****.
    3 different brake shops are baffled. The rotor to hub is so sloppy it is not even funny. You can easily turn the rotor a good 3/8" each direction with the hub staying in place. How can that be right? Am I to assume that this rotor must be positioned perfectly to work right?
    Any help you can provide is appreciated. I am this close to tossing this whole setup in the trash.
  8. #8 Re: 12" brake questions
    SW Chicago Suburbs
    what kind of pads/rotors have you used?
    when they're putting them on, is the shop coating the back of the pads liberally with anti-squeal paste? (caliper lube)
  9. #9 Re: 12" brake questions
    Las Cruces, NM
    Agreed. The original shop probably never applied greas to the pins of back of pads. The rotors are supposed to move that much. It really doean't hurt anything because teh wheel tightens the rotor in place.
  10. #10 Re: 12" brake questions
    Toronto ON
    I know the shops did, and so did I when I put them on last. The same lithium grease that we use on the pins is what we should use on the backs of the pads, correct?
  1. IPW questions
    By fst in forum PCM Tuning
    Last Post: 01-11-2008, 06:44 AM
  2. LS1 brake question
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2008, 12:14 PM
  3. questions regarding adding an aftermaket cd player to bose/onstar
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 04:34 AM
  4. There should be a "Forum Bugs/Suggestions" section
    By syP in forum Forum Bugs/Suggestions
    Last Post: 12-13-2007, 07:48 PM
