Thread: Spherical bearing upper mounts
Page 8 of 9 FirstFirst ... 6789 LastLast
Results 141 to 160 of 170
  1. #141 Re: Spherical bearing upper mounts
    Atm I'm running 10" 450 up front, 12" 350 in the rear. I was planning on switching out the fronts for a 350-400 and figured I can just reuse the springs for the rear and that's one less thing I have to buy. A 12" should work out fine for the front and I can get rid of the helpers up front too. I'll probably go with a 275-300 12" in the rear.
    04 Comp G.
  2. #142 Re: Spherical bearing upper mounts
    Never Never Land
    I ran 400 front and 350 rear with my coils. 12" springs.
  3. #143 Re: Spherical bearing upper mounts
    SE Level Member 95naSTA's Avatar
    Philly
    There was some talk on the original DIY coilover thread on CGP that 12" springs in the front can bow in and make contact with the strut. I went with 10" springs way back when because of this.
    95 Bonneville SLE: L36/F40/E39. 98 Infiniti i30: VQ35HR/5MTVLSD. 07 Ducati Monster S2R 800: DS1000 swap. 74 Yamaha DT175: Brap.
  4. #144 Re: Spherical bearing upper mounts
    Never Never Land
    I would say that's true. My sleeves had rub marks from the springs.
  5. #145 Re: Spherical bearing upper mounts
    hangover park IL
    ~James~ Psychotic Gearhead
  6. #146 Re: Spherical bearing upper mounts
    Gasp
    04 Comp G.
  7. #147 Re: Spherical bearing upper mounts
    hangover park IL
    115/127lb injectors for the TR too....
  8. #148 Re: Spherical bearing upper mounts
    Philly
    Noice.
  9. #149 Re: Spherical bearing upper mounts
    Arizona
    Mine mine mine mine mine mine mine
  10. #150 Re: Spherical bearing upper mounts
    Nah mine, since you be inactive these last few days
    04 Comp G.
  11. #151 Re: Spherical bearing upper mounts
    hangover park IL
    you two should thumb wrestle to the death
  12. #152 Re: Spherical bearing upper mounts
    Challenge accepted if it comes to that
    04 Comp G.
  13. #153 Re: Spherical bearing upper mounts
    Jan 2009
    Tallahassee, FL
    I'll drive over Redcrap and we can thumb war it out.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  14. #154 Re: Spherical bearing upper mounts
    Arizona
    Quote Originally Posted by REDCRAPGP View Post
    well I started this thread, pulling rank lol
  15. #155 Re: Spherical bearing upper mounts
    Oh no you didn't
    04 Comp G.
  16. #156 Re: Spherical bearing upper mounts
    Arizona
    Lmao
  17. #157 Re: Spherical bearing upper mounts
    hangover park IL
    well i didnt realise that was that small of a pic on the uploader....
    here's a better one. plates/cups should be welded up here shortly for one set other than the TR's
  18. #158 Re: Spherical bearing upper mounts
    hangover park IL
    red with the blue hardware just screams "made in the usa"
  19. #159 Re: Spherical bearing upper mounts
    SE Level Member buford1972's Avatar
    Apr 2009
    Peoria, Arizona
    I would be interested in a set of the plates that are the last picture on page 8. I would also be interested in the matching pair for the rear. What would you like to get for a set of these? Thanks
  20. #160 Re: Spherical bearing upper mounts
    hangover park IL
    you buying the cups and bearings and welding them yerself? I bought hardware in bulk so that's covered
  1. upper motor mounts
    By Akuch26 in forum Engine
    Last Post: 09-10-2014, 11:18 AM
  2. Upper motor mounts
    By luckytii7 in forum Wanted To Buy - Parts
    Last Post: 08-19-2013, 07:16 PM
  3. engine upper mounts
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2012, 09:13 AM
