Thread: Spherical bearing upper mounts
Page 9 of 9 FirstFirst ... 789
Results 161 to 170 of 170
  1. #161 Re: Spherical bearing upper mounts
    hangover park IL
    I have the jig welded for machining the LBJ plates for the monoball cup at a 14* angle so you can use monoball pins in the knuckle to adjust the roll center and regain the correct LCA angle
    im at least doing two pairs, wondering if anyone else is interested
    ~James~ Psychotic Gearhead
  2. #162 Re: Spherical bearing upper mounts
    Arizona
    James u kno i am
  3. #163 Re: Spherical bearing upper mounts
    Apr 2017
    Arizona
    Hello, sorry to jump in here with a different subject. Do anyone have experience or know a write up on how to install new radiator on 08 gxp. I became the owner of an 08 gxp with 69100 miles a few days ago. I am flushing cooling system and found a little white calcium deposit on seam. like to change it b4 summer. I have front fascia off and fans ready to come out. but every item loosened requires another or several items to be removed b4 original part can be taken out. any help is appreciated.
    Thank you,
    RTDgxp08
  4. #164 Re: Spherical bearing upper mounts
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    And you thought this would be the best thread to ask in why?
    GPONA #1 Cyber Bully
  5. #165 Re: Spherical bearing upper mounts
    SE Level Member buford1972's Avatar
    Apr 2009
    Peoria, Arizona
    Quote Originally Posted by Turbocharged400sbc View Post
    you buying the cups and bearings and welding them yerself? I bought hardware in bulk so that's covered
    No, it would be easier to purchase everything welded and ready to install. Living in an apartment inhibits my ability to use my 220v welder.
  6. #166 Re: Spherical bearing upper mounts
    hangover park IL
    I have a few pieces machined....
  7. #167 Re: Spherical bearing upper mounts
    Apr 2009
    Peoria, Arizona
    Hello Turbocharged, I'm still interested in a pair of these LBJ plates and monoball cups. Do you have the monoball pins also? If you don't have the pins and I was to purchase these from you, would you mind providing a part number and retailer so I can purchase the correct items? Also, I would still like to purchase a set of the front and rear spherical bearing upper mounts from post #159. Color isn't an option if it would be easier on you. Thanks
    Comp Cams Cam. #150 springs. roller rockers. CNC heads. 3.4" pulley. P&P Gen V. 8-rib w/belt wrap. N* & LQ4. 1" phenolic spacer. P&P/coated LIM. boost temp gauge. Aeromotive fuel rails. underdrive W/P pulley. coated TOG headers. Magnaflow cat back. Random Tech DP & Cat. balance shaft delete. built trans. Hughes converter.
  8. #168 Re: Spherical bearing upper mounts
    hangover park IL
    you do know that the Roll center correcting lower ball joint and mono ballpins require use of the Steel Dorman knuckle right?
    The steel 9c1 knuckle is a little skimpy compared to the Dorman but will work as well. Both requires drilling lbj taper hole top from 14mm to 5/8ths
    Thas alot of $ just in the bearing cups/bearings lol
    We have 2 sets of chromoly pins/spacers and knuckles from the initial suspension design we had for the twin engine 442 project.
    I designed this stuff for big dog builds...so I didn't skimp on a damn thing lol
  9. #169 Re: Spherical bearing upper mounts
    Arizona
    James let me know when your ready bro lol
  10. #170 Re: Spherical bearing upper mounts
    Apr 2009
    Peoria, Arizona
    Turbocharged, I didn't know about the iron knuckles so that is now on the to-do list and the drilling of the LBJ mount doesn't scare me. I'm ready to go "Big Dog" as you put it and upgrade the suspension. Here in AZ the work commute or the quick trip to WalMart for groceries can be a little aggressive at times. LOL
    If I have the correct part numbers, Summit has the FK CPW-12 cups for $12.97 each and the FK WSSX12T spherical bearings for $21.97 each. The UB Machine monoball pins are $18.20 each which comes to $106.28. I think I can manage that as long as I can get a set of your LBJ plates.
  1. upper motor mounts
    By Akuch26 in forum Engine
    Last Post: 09-10-2014, 11:18 AM
  2. Upper motor mounts
    By luckytii7 in forum Wanted To Buy - Parts
    Last Post: 08-19-2013, 07:16 PM
  3. engine upper mounts
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2012, 09:13 AM
