Thread: Wheel Bearing Bracket
Results 1 to 12 of 12
  1. #1 Wheel Bearing Bracket
    Oct 2014
    Minnesota
    Hello all. I found out that my front wheel bearings on my 1998 GTP both needed replacement shortly after I got new tires. I got the passnger side replaced, which was a complete pain. I went to replace the driver's side and the three 13 mm bolts holding the bearing assembly onto the bracket were rusted in pretty badly. Between the odd angle and rust, I managed to strip/round the heads on the bolts (insert many, many choice words here).
    I am looking for a replacement for that bracket so I can just junk the current bracket and bearing assembly. Any suggestions? I am going to check with one parts store after work, but I am wondering if salvage yards would be a better option. Feel free to let me know if you have one for sale yourself. I think/hope I successfully attached a diagram of what I am talking about. The bracket I am referring to attaches directly to the strut and the bearing bolts onto it with the previously mentions three 13 mm bolts.
    Thanks for any help!
    Wheel Bearing  Bracket Attached Images
  2. #2 Re: Wheel Bearing Bracket
    Normal parts stores likely won't have them. It's not expected to go bad.
  3. #3 Re: Wheel Bearing Bracket
    St. Louis
    That's called a steering knuckle. Oreilly's shows them, Dorman brand. Around $220 per side. Rock Auto would probably have it as well. I'm thinking junkyard on this one if you can.
  4. #4 Re: Wheel Bearing Bracket
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Someone on here iirc was selling powdercoated ones i thought.
    Edit: no dice, couldn't find em.
    Sent from BFE
    2012 F150 STX
    - Gonna be a race truck
  5. #5 Re: Wheel Bearing Bracket
    Whoa..I think he's only looking for the bracket guys.. not the knuckle
    Oh geez.. just reread.. that's no bracket..that's a knuckle.
    Look up HighOctaneRacing there Kyle..
  6. #6 Re: Wheel Bearing Bracket
    Apr 2012
    Dayton, OH
    I found it for him thanks Bill, not powercoated just sand blasted
    http://www.grandprixforums.net/showthread.php?t=84850
    Sent from BFE
    2012 F150 STX
  7. #7 Re: Wheel Bearing Bracket
    Yeah.. you like how I sent you to find that for me. lol
  8. #8 Re: Wheel Bearing Bracket
    Apr 2012
    Dayton, OH
    I did.....
    Sent from BFE
    2012 F150 STX
  9. #9 Re: Wheel Bearing Bracket
    This is how Scotty got started...
  10. #10 Re: Wheel Bearing Bracket
    Enfield, CT
    Thanks Bill and Kyle for throwing me a bone. I've PM'd zkc27
  11. #11 Re: Wheel Bearing Bracket
    Apr 2012
    Dayton, OH
    Anything for a fellow Kyle
    Even tho Bill really did all the work bossing me around and all that fancy stuff.
    Sent from BFE
    2012 F150 STX
  12. #12 Re: Wheel Bearing Bracket
    Enfield, CT
    Sent from BFE
    LOL. That's Bill!
  1. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  2. Wheel rocking still... already changed wheel bearing. Ideas?
    By jmn in forum Introductions/Noob Questions
    Last Post: 09-30-2013, 09:27 AM
  3. Another wheel bearing?
    By smoke14 in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2013, 06:07 PM
  4. wheel bearing hub
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2011, 09:43 AM
  5. wheel bearing
    By mosley in forum General Tech Discussion
    Last Post: 04-04-2011, 08:16 PM
