Thread: brembo 13.6 kit
Results 1 to 8 of 8
  1. #1 brembo 13.6 kit
    Jun 2014
    Alabama
    Anyone use this kit from zzp yet? Looking for reviews. I want my 2007 to stop better. Will it mess with my abs and throw a light?
  2. #2 Re: brembo 13.6 kit
    Aug 2013
    McDonald PA
    Just get fbodies and drilled and slotted rotors. Ss brake lines and profit lol
  3. #3 Re: brembo 13.6 kit
    GTP Level Member buickman104's Avatar
    NYC
    That zzp brake kit is like the cts-v brake kit except the rotor is slightly smaller. With 4 piston brembo brakes and 14 inch rotors my car stops amazingly. The negative is that the front is end will stop so much better than the rear that you will get more nose plow when you brake hard. That is why I upgraded to rear GXP brakes. The other negative is that with the 14 inch rotor and caliper you have to upgrade to 18 inch wheels which are not as good for ride comfort if you live in an area with bad roads.
    this brake kit uses a 13.6" rotor and therefore I wonder if you can squeak away with a 17" rim.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: brembo 13.6 kit
    Arizona
    There also using the rear calipers off the camaro for the kit. The piston size is slightly smaller. Then the cts-v/camaro as fronts
  5. #5 Re: brembo 13.6 kit
    Dec 2010
    ATL,Georgia
    ^ this... just another ZZP rip off of R&D that someone did first (ie. Drunkie). Just piece together your own kit.. cts-v front calipers, gt500 rotors, ss brake lines, bolts and washers and you will still be under what you pay for their kit I bet!
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  6. #6 Re: brembo 13.6 kit
    Jun 2014
    Alabama
    Thanks for the info guys. I forgot to mention I'm already running 18's. I may just go with the fbodies with slotted rotors and stainless lines. However I have heard of people having problems with caliper spread with the fbody setup?
  7. #7 Re: brembo 13.6 kit
    Arizona
    Or you can buy my GXP setup
  8. #8 Re: brembo 13.6 kit
    Jun 2014
    Alabama
    How much for the gxp setup?
  1. CTS-V brembo calipers with pads and pin kit
    By OmegaRed in forum For Sale - Parts
    Last Post: 10-12-2013, 10:35 PM
  2. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  3. Brake Review - Brembo/Hawk HPS
    By tonkota in forum Brakes/Suspension/Chassis
    Last Post: 02-12-2009, 11:43 AM
