Thread: Front Sway Bar Bushing Bracket Bolt Trouble
Results 1 to 11 of 11
  1. #1 Front Sway Bar Bushing Bracket Bolt Trouble
    SE Level Member Jackd90's Avatar
    Chicago
    Hey guys and gals,
    Today I went and tried to do a quick swap (first time) of my front sway bar bushings to the energy suspension bushings. The suspension is basically stock, 2004 Grand Prix GT2. The problem I was having was that the rear bolts were spinning and not actually coming out (both passenger and driver side). The front bolts on the bushing bracket came out just fine. Is there something I'm not doing right? Do I have to hold the bottom of the bolt or push it up? It bolts to the subframe and it's in a hollowed out section. Thanks!
    Open Cone Intake, 180° Tstat, Autolite 605 Coppers, Autolite 7mm wires (will upgrade soon), Muffler delete (headers soon)
  2. #2 Re: Front Sway Bar Bushing Bracket Bolt Trouble
    sounds like the bolts are stripped out from the last guy who did bushings or the bar.
    its easier to get them bolts out if you lower the back of the sub frame 2 inches. this gives you more room to work a ratchet in.
    if you can pull up while turning the bolts ( vice grips) maybe they will catch threads again and come out.
    chances are you'll need to drill and tap the holes and get new bolts.
  3. #3 Re: Front Sway Bar Bushing Bracket Bolt Trouble
    Oct 2011
    Toledo, OH
    As Scotty said, it's probably stripped. It's only aluminum after all. Instead of using vise grips, see if you can get a flat head screwdriver under the bracket at the bolt and pry upward while trying to unbolt it.
    It will be damn near impossible to get a drill and tap in there. Your best bet would be to get the bolt out, and saw off the aluminum tube that the bolt goes through and find a nut and washer that will fit.
    7"
  4. #4 Re: Front Sway Bar Bushing Bracket Bolt Trouble
    yeah the screw driver pounded in or a very small pry bar under the head, then try to ratchet it out also works.
  5. #5 Re: Front Sway Bar Bushing Bracket Bolt Trouble
    Oct 2011
    Toledo, OH
    If the tube broke free from the frame and is spinning, you may be able to grip it with pliers and get the bolt out of it.
    But you can use a hacksaw blade and cut it off and put a nut and washer in it's place.
    Front Sway Bar Bushing Bracket Bolt Trouble Attached Images
    7"
  6. #6 Re: Front Sway Bar Bushing Bracket Bolt Trouble
    damn, look at all the room you got there!!!!! steel frames blow.
    thats the driver side too aint it? that side is so tight with brake lines on my car i have to drop the sub frame to get the rear bolts out.
  7. #7 Re: Front Sway Bar Bushing Bracket Bolt Trouble
    Oct 2011
    Toledo, OH
    Yep my drivers side. It's still pretty tight though, tight enough that I couldn't get a ratchet in there and had to use a wrench 1/8 turn at a time.
    7"
  8. #8 Re: Front Sway Bar Bushing Bracket Bolt Trouble
    with the frame dropped, i use a 3 inch extension and snake the socket through the brake lines. works like charm. no way to get them out with out dropping the frame in my eyes, not the way the brake lines run past there. pass side is doable, but easier with the frame dropped a few inches.
  9. #9 Re: Front Sway Bar Bushing Bracket Bolt Trouble
    Chicago
    Dang. Well, the tube part definitely spins on both sides. Is the tube supposed to be attached to the frame?
  10. #10 Re: Front Sway Bar Bushing Bracket Bolt Trouble
    probably, see if you can hold it with vice grips, find a nut and washer to replace the sleeve.
  11. #11 Re: Front Sway Bar Bushing Bracket Bolt Trouble
    Chicago
    Thanks! I'll try that this weekend.
  1. Front sway bar bushings and bracket?
    By Akuch26 in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2014, 10:13 AM
  2. sway bar bushing help
    By kking89 in forum General Tech Discussion
    Last Post: 07-29-2013, 04:45 PM
  3. BMR Sway bar bushing PN or supplier?
    By Haney GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2013, 06:22 PM
  4. Oil pan gasket - removing 15 mm bolt at top/rear of front engine mount bracket - 2004
    By jkk9 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2011, 06:40 PM
  5. GXP Brake Caliper Bracket bushing
    By Spartan GL in forum Brakes/Suspension/Chassis
    Last Post: 06-05-2011, 04:43 PM
