Thread: Question on bleeding CTS-V Brakes
Results 1 to 5 of 5
  1. #1 Question on bleeding CTS-V Brakes
    Jun 2013
    Metro Detroit
    Hey guys, while my car was under the knife this past weekend, I had to open the bleeder screw on my passenger front caliper to get it back over the Rotor. I'm going to bleed the brakes tonight, but do I have to do all 4 corners, or can I just do the Fronts? I read somewhere that the master cylinder is split into 2 (Front and back).
    Any help is appreciated. Thanks!
  2. #2 Re: Question on bleeding CTS-V Brakes
    you can do just that caliper if you like. you only opened the one it seems. why im not sure. you can C clamp the pistons to make them open up with the bleeder closed, the fluid just pushes back up to the master's res.
  3. #3 Re: Question on bleeding CTS-V Brakes
    Jun 2013
    Metro Detroit
    I tried, but it was rock hard and the clamp was starting to take the powder coating off. So I just unscrewed the bleeder and pushed the piston down. I'll just do the one I cracked (maybe the 2 fronts). I just didn't want to have to do all 4...
    thanks man.
  4. #4 Re: Question on bleeding CTS-V Brakes
    oh, that pretty finish. i hear ya. they sell a tool for like 10 bucks, works on the inside, it dont touch the outside finish.
  5. #5 Re: Question on bleeding CTS-V Brakes
    Dec 2010
    ATL,Georgia
    Hold on you couldn't get the piston pushed back in even with a c-clamp?.. you should be able to push them in with your hand.. did you take the cap off the brake fluid reservoir?
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  1. HELLPPP! Need some help with bleeding brakes issue
    By douellette88 in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2014, 09:51 PM
  2. Is there a speical procedure for bleeding the brakes?
    By indygrandprix in forum Brakes/Suspension/Chassis
    Last Post: 08-30-2013, 09:42 AM
  3. Bleeding the brakes...
    By 87IROCZOWNER69 in forum General Tech Discussion
    Last Post: 08-18-2012, 12:44 AM
  4. anyone had this problem bleeding brakes
    By gtcoup in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2011, 05:05 PM
  5. RE: New Brakes? Old question?
    By pbxcomm in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2011, 11:15 AM
