I've had this car since januRy and have rebuilt the whole damn car as far as the suspension goes and I'm still getting a clicking noise from the front end when I turn the steering wheel certain ways
The list:
New-
Front: loaded struts sway bar links and bushings lower control arm bushings and ball joints front wheel bearings brake lines and oem gm half shafts
And as for the rear the same everything new not even 100 miles on these parts also I changed the intermediate steering shaft put new rims and tires on and the car drives and handles smooth as ever but the clicking noise is driving me nuts I'm lead to believe it's the rack but I've been told it's not. :/ wth could it be everything was done right and greased/ torqued to spec I assure you
