Thread: Help 05 gxp front steering noise/issues
Results 1 to 6 of 6
  1. #1 Help 05 gxp front steering noise/issues
    Jan 2014
    United States
    I've had this car since januRy and have rebuilt the whole damn car as far as the suspension goes and I'm still getting a clicking noise from the front end when I turn the steering wheel certain ways
    The list:
    New-
    Front: loaded struts sway bar links and bushings lower control arm bushings and ball joints front wheel bearings brake lines and oem gm half shafts
    And as for the rear the same everything new not even 100 miles on these parts also I changed the intermediate steering shaft put new rims and tires on and the car drives and handles smooth as ever but the clicking noise is driving me nuts I'm lead to believe it's the rack but I've been told it's not. :/ wth could it be everything was done right and greased/ torqued to spec I assure you
    THE RIDES OF 2014​ 98' dodge ram 1500 sport/raminator-DD
    97' ford f-150 xlt-mud toy
    97' monte carlo z-34-project never to be done
    05' grand prix gxp-weekend warrior
  2. #2 Re: Help 05 gxp front steering noise/issues
    GTP Level Member buickman104's Avatar
    NYC
    Tie rod ends?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: Help 05 gxp front steering noise/issues
    Jan 2014
    United States
    Quote Originally Posted by buickman104 View Post
    Tie rod ends?
    My bad
    Of course I have replaced both sides inner and outer tierod ends
    I knew I forgot to mention somthing
  4. #4 Re: Help 05 gxp front steering noise/issues
    Mercer, Pa
    In parking lot and you are moving slow or not moving. Turn wheel and get a couple clicks?
    Splined steering shafts on some years would get a skip stick condition when the splines had to slide.
    GM makes a grease kit for $15-$20. I emptied a can of fluid film into the boot under dash and got rid of my click.
  5. #5 Re: Help 05 gxp front steering noise/issues
    Jan 2014
    United States
    Quote Originally Posted by sseilmnop View Post
    It sounds like ur talking about the intermediate steering shaft that goes through the firewall? And I've changed that out less than 20 miles ago it took a lot of fine tuning to get it tight and to get the steering sensor just right so the traction control and abs would quit going hay wire. I'm positive it's not coming from that area of the car.
  6. #6 Re: Help 05 gxp front steering noise/issues
    HUDSON
    Check and make sure the steering rack and pinion mounting bolts are good and tight.
  1. New front brakes and now a squeaking noise up front
    By Trann14 in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2013, 08:45 PM
  2. Steering Issues
    By Dante in forum General Tech Discussion
    Last Post: 09-24-2012, 02:01 PM
  3. steering noise HELP
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2011, 01:28 PM
  4. Front suspension/steering issues
    By 07CrimsonGT in forum Brakes/Suspension/Chassis
    Last Post: 05-25-2009, 08:52 AM
  5. Steering issues
    By kacarter in forum General Tech Discussion
    Last Post: 05-22-2009, 12:41 PM
