Thread: Suspension Replacements
Results 1 to 6 of 6
  1. #1 Suspension Replacements
    Aug 2013
    arlington, tx
    I'm looking at replacing pretty much all of the suspension components on my 04. I was just wondering what all I would need for the rear. In the front i'm ordering new Moog LCA's, inner and outer tie rods and I have already replaced the sway bar end links with Moog's as well. Should I replace anything else under there? What bushings do I need to add to the list? In the rear so far I have ordered the sway bar end links and that's it.
  2. #2 Re: Suspension Replacements
    Oct 2011
    Toledo, OH
    http://www.grandprixforums.net/threa...ssing-anything
    There's what I bought when I did my complete replacement.
    7"
  3. #3 Re: Suspension Replacements
    Aug 2013
    arlington, tx
    What exactly do the trailing arms do? Are those like the equivalent to the LCA's in the front?
  4. #4 Re: Suspension Replacements
    Before I call you a girl again by mistake.. go check out what I did on my Regal. Do it and you'll love your car.
  5. #5 Re: Suspension Replacements
    Aug 2013
    arlington, tx
    What is the thread title so I can search it?
  6. #6 Re: Suspension Replacements
    Oct 2011
    Toledo, OH
    Quote Originally Posted by luckyg817 View Post
    Sort of. Fixed pivot points for rear tires.
    7"
  1. 2004 gtp comp g Suspension replacements
    By jrprattjr in forum Introductions/Noob Questions
    Last Post: 06-17-2013, 10:42 AM
  2. Headlight replacements on a '94 SE
    By Gravekeeper in forum Visual/Body Modifications
    Last Post: 03-22-2012, 10:09 AM
  3. 6x9 replacements
    By coreygnar in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2011, 10:42 PM
  4. OEM replacements?
    By BSmout in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2009, 03:41 PM
  5. Good Replacements
    By stlmo_gtp in forum Audio, Security & Visual Electronics
    Last Post: 05-15-2009, 09:52 AM
