Thread: ABS Delete
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 65
  1. #1 ABS Delete
    Apr 2013
    Belleville, IL
    Has Anybody done an ABS delete in these 97-03 GP's?
    Just wondering, as it is very annoying at times
  2. #2 Re: ABS Delete
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Take the fuse out. Simple.
    GPONA #1 Cyber Bully
  3. #3 Re: ABS Delete
    Omaha, NE
    ABS is annoying...?
    Have you thought about fixing your drving style?
  4. #4 Re: ABS Delete
    Apr 2013
    Belleville, IL
    ABS is annoying...?
    I don't drive erratic, and I'm glad you like and enjoy replacing hubs.Guess I'm asking for too much here.
  5. #5 Re: ABS Delete
    Jan 2012
    Canada
    Quote Originally Posted by blackbird89 View Post
    Dont get cheap hubs, problem = solved
    2001 GTP Special Edition - 3.29's built tranny, Coilovers with agx struts, 04+ seats, 18" Eagle 077's, Ported heads, ported blower, pacesetters, 3.4"
    2004 BMW 325CI with the sport package and the correct amount of pedals.
  6. #6 Re: ABS Delete
    Omaha, NE
    You don't have to "delete" ABS to resolve your issue. As said before, pull the fuse, and tune out the code. How much money do you really think you're going to be saving this way?
    If you are in an accident where braking was necessary and you have disabled factory ABS, you can be found at fault for the accident wether it was your doing or not, and can face fines, etc.
  7. #7 Re: ABS Delete
    Apr 2013
    Belleville, IL
    Didnt know you could tune it out.Any links to such?
    Also haven't replaced any twice its just a hassle anytime I do. By no means hard, just not a fan of these sealed units.
  8. #8 Re: ABS Delete
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    If the hub is broken then the abs has deleted itself.
  9. #9 Re: ABS Delete
    Omaha, NE
    You don't tune out the ABS, you Tune the code out so it stops reporting and gets rid of the light on your dash.
  10. #10 Re: ABS Delete
    Apr 2013
    Belleville, IL
    I understood what you meant. As I said wasn't sure that tuning the code out was an option.So essentially can tune all 4 out to report to pcm, is that what your saying? HP Tuners can do that do you know?
  11. #11 Re: ABS Delete
    Jan 2012
    Canada
    Or you can just pull the bulb out....
  12. #12 Re: ABS Delete
    Apr 2013
    Belleville, IL
    Going to pass on that option lol
  13. #13 Re: ABS Delete
    Sep 2011
    MI
    This is going to seem like a real troll thing to say, but, are you just looking to spend money? All you have to do is pull the fuse and pull out the ABS light bulb. Both can be done for nothing... yet you seem like you'd rather have someone program out the system? And what kind of shady mechanic/tuner is going to want the liability of disabeling a safty feature on your car?
  14. #14 Re: ABS Delete
    SWPA
    ABS flat out SUCKS. It makes stopping distances worse. Everytime is has engaged on me I have went PAST the point I wanted to stop. I can stop easier and faster without it. On snow and gravel ABS is your worst enemy.
    And no, you can't be fined for disabling your ABS.
  15. #15 Re: ABS Delete
    Nov 2011
    NY
    First.. Unless a death is involved, I seriously doubt there'd be any forensic dissection of the vehicle in the event of an accident regarding the abs system. That said, with the system disabled, regardless of whether intentional or not, you are serious limiting your stopping distance in most scenarios. You're better to fix it than wasting effort to delete it. The person you save from needing new teeth, going through the windshield or requiring cosmetic surgery just might be you!
    Just sayin...
    Have a nice day!
  16. #16 Re: ABS Delete
    SWPA
    Here's the funny thing, NOT ALL CARS COME WITH ABS.
    If it was really that big of a "safety factor" it would have been a requirement to be installed for the past 20+ years, like airbags. But even with airbags, it is not illegal to disable them either since they are a SECONDARY restraint system.
  17. #17 Re: ABS Delete
    Mar 2013
    St. Louis
    For anyone that decides to disable airbags and ABS please post vin numbers and location so I know not to buy or drive anywhere near your vehicles.
    Sent from my SPH-L710 using Tapatalk 2
  18. #18 Re: ABS Delete
    SWPA
    So airbags affect how a car drives and handles? ABS does too? Are you going to avoid cars that come from the factory WITHOUT ABS?
  19. #19 Re: ABS Delete
    i really dont have these abs problems, you need to learn how to use the abs, standing on the brake pedal is still the worst thing you can do if you need to stop asap. with or with out abs. in any weather condition.
    as soon as i feel abs kick in, im off the brakes for a second, then back on them but not as hard as i was a second ago, as long as your not pushing to hard, abs wont kick in.
    and ill add, i did the F body brake up grade, i have even less issues with the abs now. in the rain the car just flat out stops even if i stand on the brakes. snow it will still kick in, but no wheres near as bad as these stock crappy brakes do.
  20. #20 Re: ABS Delete
    SWPA
    Scotty, the two times ABS screwed me the most, I was going LESS than 10 mph and barely tapped the brakes. I've drove non ABS equipped cars for 13 years before I got the GP and NEVER had the issues I have experienced with non ABS that I have with ABS.
    Disabling ABS is not going to make your car any less safe unless a complete moron is behind the wheel. If the driver knows what they are doing non ABS gives them more control.
  1. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  2. delete
    By all charged up in forum General Tech Discussion
    Last Post: 08-13-2010, 09:49 PM
