Thread: Stiffer rear suspension? 97-03
Results 1 to 14 of 14
  1. #1 Stiffer rear suspension? 97-03
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    Aside from the Intrigue springs already on the rear what else can be done to help stop the back from squating down so hard under acceleration?
    This thing is trying to pull a wheelie under WOT.
  2. #2 Re: Stiffer rear suspension? 97-03
    Cambridge, Ontario Canada
    Replace springs with blocks of wood
    2005 E55 - stock
  3. #3 Re: Stiffer rear suspension? 97-03
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    The squat is going to happen anyway imo its just the weight transfer, unless you running on a track it shouldn't be a huge problem unless you wanted to really sink some money into the suspension.
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: Stiffer rear suspension? 97-03
    GTP Level Member buickman104's Avatar
    NYC
    Spring blockers, stiffer shocks, or front springs in the rear.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: Stiffer rear suspension? 97-03
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    If Riviera springs would fit I would think they would be stiffer. But I have no idea just throwing thoughts out there. I'm sure someone who knows more can tell me I'm wrong. lol
    I went NA when a whore left -$300 in my bank account.
  6. #6 Re: Stiffer rear suspension? 97-03
    hangover park IL
    Rivieras are air assisted coil spring trailing arms
    G, C, H & B bodies are different from the W.
    it may be that the springs will work and are stiffer but even though the control arm leverage ratio at the spring is higher with the trailing arm...that and the air suspension (air assist shocks) I don't think that would necessarily mean the coil spring has a higher spring rate than say a 9c1 imp rear spring
    ~James~ Psychotic Gearhead
  7. #7 Re: Stiffer rear suspension? 97-03
    hangover park IL
    I will say it ...front springs on the back is the bee's knees... cuz your car will ride level with all your tools and crap in it and then you go to the track... empty it out and she's sitting with her ass in the air like she wants to be stabbed with your pecker
  8. #8 Re: Stiffer rear suspension? 97-03
    Apr 2012
    Dayton, OH
    Lmao
    Sent from the Milky Way
    2012 F150 STX
  9. #9 Re: Stiffer rear suspension? 97-03
    Buffalo
    Cargo springs
  10. #10 Re: Stiffer rear suspension? 97-03
    May 2014
    Colorado
    Quote Originally Posted by Turbocharged400sbc View Post
    First of all that's hilarious.
    Second of all, just front springs on the rear struts, or the strut and spring assembly for the front on the back.
  11. #11 Re: Stiffer rear suspension? 97-03
    Apr 2012
    Dayton, OH
    Cant use the whole front assembly on the back. Would have to be springs.
    2012 F150 STX
  12. #12 Re: Stiffer rear suspension? 97-03
    May 2014
    Colorado
    Thanks guys, Guess next Saturdays project is booked.
  13. #13 Re: Stiffer rear suspension? 97-03
    hangover park IL
    youll grind a portion of the lower spring seat to remove a high spot,, just rtv below durring final assembly (clean rust/crud), dont use an issolator
    the upper your going to toss the oe spring swash plate but keep the inner portion, your making a union of the oem Front and rear upper hats, and top hat to hold spring centered. up top i shoulda made a centering washer instead but i didnt care, we wanted to hurry up and break the trans in the TR yet again....
  14. #14 Re: Stiffer rear suspension? 97-03
    New York
    I have the intrigue Springs on mine with 2001 Monroe Sensatrac Impala police struts.No squatting on acceleration...
  1. rear suspension????
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-07-2010, 04:29 PM
  2. rear suspension, 04+
    By sportred04 in forum General Tech Discussion
    Last Post: 03-09-2010, 07:20 PM
  3. rear drag suspension
    By elusive racing in forum Brakes/Suspension/Chassis
    Last Post: 02-13-2010, 02:51 PM
  4. Rear suspension help
    By thirdgenfcarnut in forum Brakes/Suspension/Chassis
    Last Post: 08-16-2009, 04:25 PM
  5. Stiffer Suspension and aftermarket feel HELP
    By rczzv in forum General Tech Discussion
    Last Post: 05-13-2008, 11:50 AM
