Thread: Strut Options for making coilovers
Page 5 of 5 FirstFirst ... 345
Results 81 to 99 of 99
  1. #81 Re: Strut Options for making coilovers
    Never Never Land
    Still trying to find more info on those coils posted on the first page. All I know is they're off of an 07-11 Camry and made by D2.
  2. #82 Re: Strut Options for making coilovers
    SE Level Member 95naSTA's Avatar
    Philly
    The top hat is the easiest part to convert. You just need to water jet the part that mounts to the body.
    If someone were able to find a bottom mount that was close, thickness and bolt pattern wise, that would help.
    Otherwise, chopping the bottom mounts, welding on new flanges, and machining or water jetting a new top mount (like Kuntzie) really isn't that bad.
  3. #83 Re: Strut Options for making coilovers
    yeah, the top mount is the easy part, especially if the top hats come apart in halves to expose the bearing which would make it so you only have to make the top half of the top mount where the actual studs press through.
  4. #84 Re: Strut Options for making coilovers
    Never Never Land
    Someone just needs to figure out how to do budgets bags. I'd be all over that
  5. #85 Re: Strut Options for making coilovers
    hangover park IL
    i ended up designing mine around the W strut bucket. im using the fk-16 bearing that allows me to make the strut shaft receiver at any height to prevent bottoming the shaft, no matter how long the strut/shaft is
    best part is the bearing is rated 4 times stronger than std sized cc plate uniballs lol
    ~James~ Psychotic Gearhead
  6. #86 Re: Strut Options for making coilovers
    GTX Level Member Bakerdd's Avatar
    Raleigh, NC
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    Assuming you already had coilovers, theres the bag over coil option and then you just have to buy the management... still not that cheap though. And theres no way it would be worth doing on the zzp/ht coilovers. Shorter struts are definitely a must
  7. #87 Re: Strut Options for making coilovers
    Never Never Land
    400sbc has some fancy stuff going on lol. Not sure what the fk-16 bearing is
    More info on that Baker? Never heard or seen that before.
  8. #88 Re: Strut Options for making coilovers
    hangover park IL
    The race is 2.125"od
    Id is 1"
    Its big
  9. #89 Re: Strut Options for making coilovers
    Howell, NJ
    Its the same thing as coilovers except you replace the coil/spring with a bag. It gives you more adjust ability option, so that you can run higher or lower psi at at any given ride height.
    But you wont get anywhere unless you find shorter struts.
  10. #90 Re: Strut Options for making coilovers
    Never Never Land
    Right. That's still an ongoing battle. I think the only option is inserts which I have no problem with. I'll gladly hack up a strut and put a quality shock insert in it. But even then, finding which inserts are the correct length is proving to be a challenge.
  11. #91 Re: Strut Options for making coilovers
    hangover park IL
    i went the other way....the larger bearing lets me position the top of the strut shaft at any point above or below the ball.
    planning on using the mustang strange type double adjustable's in the future. though they also offer bare struts that you can cut plates for and weld.
    with the traction bars we might not need compression adjust-ability for the rear...though if we roadcourse it...lol
  12. #92 Re: Strut Options for making coilovers
    Arizona
    Quote Originally Posted by Turbocharged400sbc View Post
    If you have a cal ranch or tractor supply...look into the tractor section they have tractor top links that can chopped up and serve as suspension components and top bearings.
    I'm currently mocking up a set for a trailing arm replacement for straight bearings instead
  13. #93 Re: Strut Options for making coilovers
    Arizona
    If you want my old koni retrofits that are blown out you can get them. All you have to do is ship them off to koni. And redo the sleeves since they got damage when I moved houses
  14. #94 Re: Strut Options for making coilovers
    Never Never Land
    How many doll hairs for these blown Koni retros? And you're talking the sleeve the adjuster nut sits on correct?
  15. #95 Re: Strut Options for making coilovers
    Arizona
    Its the front set only though 150 sound good
  16. #96 Re: Strut Options for making coilovers
    Never Never Land
    I'll pass on those. Still interested in the coilover bags though. Where does one buy those at? Air ride is totally new to me.
  17. #97 Re: Strut Options for making coilovers
    Dec 2010
    ATL,Georgia
    There would be some obstacles unfortunately... First you would have to make your own coilover bags setup... if you made a set of coilovers you can get a set of Air Ride universal air bellows(double is preferred!) then mount up a bottom plate of some sort for the bags to rest on(not hard), then you would have to figure out the top plate (again not hard).... Buuuuut the biggest obstacle would be the strut rod not being short enough(hard lol)... you can slap some universal bags on some struts.. sure.. but think about how much lower air can go compared springs... you will bottom the strut out real quick with an air bag/stock strut combo.. unless the struts are made specifically for air bags(ie shorter rod length and valving) you would have to get a strut re-machined and re-valved in order to make it work really. hope this clears some things up for you.
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  18. #98 Re: Strut Options for making coilovers
    strut rod not being short enough: cut rod down an inch or two, rethread. VW guys do it all the time.
    that isn't going to help you with an overall shorter body length, though.
  19. #99 Re: Strut Options for making coilovers
    Never Never Land
    Probably going to end up with another set of sooper long GR2's and just making another set of coils like I had.
  1. Replace KYB Strut-Plus strut with Bilstein?
    By nik12937 in forum Brakes/Suspension/Chassis
    Last Post: 01-20-2014, 04:58 PM
  2. 08 GXP strut options
    By looong4 in forum Brakes/Suspension/Chassis
    Last Post: 02-08-2011, 12:42 AM
  3. Strut Options
    By Amb4 in forum Brakes/Suspension/Chassis
    Last Post: 06-25-2010, 05:45 PM
  4. 04+ Strut Options
    By ZR1Vette09 in forum Brakes/Suspension/Chassis
    Last Post: 05-12-2010, 05:31 PM
  5. Monroe Quick Strut vs. KYB Strut Plus...definitive?
    By FRESCOLIO in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2009, 05:27 PM
