Thread: BMR Trailing Arms
Results 1 to 6 of 6
  1. #1 BMR Trailing Arms
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    Hey everyone long time no see, I recently picked up a new set of BMR trailing arms just for the hell of it along with new LCA's, dorman front and rear sway bars, tie rod ends, just curious if there is anything special about installing the BMR arms, I read something about the factory bolt being smaller and having play in it when installed and I sure as hell don't want that. Just curious if anything special needs to be done or if I just bolt them up and gone on,I was under the impression they just bolt it ? Am I wrong I guess is what I am asking because I don't plan to drill anything out for a larger bolt.
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  2. #2 Re: BMR Trailing Arms
    GTP Level Member buickman104's Avatar
    NYC
    I have bmr trailing arms. They were straight forward bolt ons. Make sure there is a sleeve in the bushing and that is it.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: BMR Trailing Arms
    Nov 2013
    Des Moines, IA
    Looks like the sleeve is in there. So we should be good to go. Thanks for the reply !
    2007GPGTSC
    " sad thing is "
  4. #4 Re: BMR Trailing Arms
    I used umi and love them.
  5. #5 Re: BMR Trailing Arms
    NYC
    yup car corners so much better with them in.
  6. #6 Re: BMR Trailing Arms
    Nov 2013
    Des Moines, IA
    I am kinda curious to see how the rear dorman bar works. Its solid I know that not sure the size.
    2007GPGTSC
    " sad thing is "
  1. Trailing Arms
    By shawngtp in forum Brakes/Suspension/Chassis
    Last Post: 02-24-2010, 08:56 AM
  2. just an fyi--trailing arms
    By quinnp12 in forum Brakes/Suspension/Chassis
    Last Post: 02-03-2010, 12:38 AM
