Thread: Comp G springs
Results 1 to 17 of 17
  1. #1 Comp G springs
    Sep 2011
    Omaha
    So I'm on rock auto and finally have enough money to order my strut/springs and I'm looking to get the comp g springs. Is this them??
    -http://www.rockauto.com/catalog/moreinfo.php?pk=950623&cc=1429691
    - http://www.rockauto.com/catalog/more...612&cc=1429691
    3.5 in" pulley, zzp dp, custom hai, colder plugs, red wires- red means fast, Tog headers, resonater Delete, custom dyno tuned and max out injectors...
  2. #2 Re: Comp G springs
    Fe3 is what they're referred to I can't seem to find the p/n though.
    04 Comp G.
  3. #3 Re: Comp G springs
    SE Level Member Aeroheadcww's Avatar
    Williamsburg, Ky
    Comp g springs are the same as any other GP. The struts and sway bars are different.
    _____________________________________________
    '05 CompG - 3.6 Pulley, ZZP PCM, K&N drop in, Customized SD Headers, TEP Street/Strip tranny, ZZP STBs, ZZP Coilovers, GXP front brakes
  4. #4 Re: Comp G springs
    Arizona
    I got Gxp springs if you want them pm me
  5. #5 Re: Comp G springs
    Oct 2011
    Puyallup WA
    Struts are different springs are same
    08 G8 GT - exhaust Tune
  6. #6 Re: Comp G springs
    Nov 2012
    Madison
    These are your money shot part numbers for CompG springs.
    These numbers are a guarantee because I just read them off my old 2004 CompG spring tags.
    TDK 10258881
    FKJ 22133030
    Happy hunting
  7. #7 Re: Comp G springs
    Sep 2011
    Omaha
    Quote Originally Posted by spazzz View Post
    TDK 10258881
    FKJ 22133030
    Happy hunting
    Thank you good sir! And to everyone else that has helped!
  8. #8 Re: Comp G springs
    Dec 2012
    troll land
    All but gxp comp g have fe1 springs
  9. #9 Re: Comp G springs
    Sep 2011
    Omaha
    Quote Originally Posted by l67ss View Post
    Does the GXP springs raise the height? I know I've heard the struts and springs do but I didn't know if GXP springs would raise it if on, either comp g struts or KGB struts.where do you all usually buy your struts like comp g ones? Rock auto? GM parts direct?? Amazon? How much should I expect a strut to be?
    Thank you for your help!!
  10. #10 Re: Comp G springs
    Nov 2012
    Madison
    I bought mine in April from RockAuto. They had a good deal on the rears. For the fronts I looked around and it was hard to find 2 from the same place. So I went Rockauto for the fronts too. They still shipped from 2 different warehouses.
    Use RockAuto to find the numbers and do some googles to find the best deal.
    They are usually close to 100 to 125 apiece.
    Happy hunting
  11. #11 Re: Comp G springs
    Arizona
    Ill get you my Gxp springs 20+shipping
  12. #12 Re: Comp G springs
    Sep 2011
    Omaha
    Quote Originally Posted by 91parkave View Post
    What's the mileage? Will they raise my height from stock? How much of a difference are they than the regular springs?
  13. #13 Re: Comp G springs
    Dec 2012
    troll land
    If the op doesnt want the gxp springs ill buy91parkav
  14. #14 Re: Comp G springs
    Arizona
    about 50k id assume like the comp g spring there slightly stiffer, however can't confirm if these will raise or not
  15. #15 Re: Comp G springs
    Dec 2012
    troll land
    Id assume theyd raise it a bit as v8
  16. #16 Re: Comp G springs
    Arizona
    the v8 is like 40lbs more than the 3800
  17. #17 Re: Comp G springs
    Sep 2011
    Omaha
    Can anyone confirm if it raises??
  1. what struts with comp-g springs?
    By papaspanky in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2012, 10:18 PM
