Thread: Front Passanger brake line
Results 1 to 19 of 19
  1. #1 Front Passanger brake line
    Aug 2011
    Orland, Me
    So I lost the front brakes driving home from work yesterday. After getting it up on the lift to see where the leak was, (a side note) I live in Maine and the winters are harsh on anything metal. To battle this I've been using Fluid
    Film which has been incredible. With one exception. Where the brake line goes over the exhaust down pipe it has a heat shield covering it. This is exactly where it rusted out. About 1" into the shield on both sides was completely rusted. The only place I could not spray... grrrr...)
    On to the question....
    Where the break lines come up and attach to the master cylinder, all 4 of them have a flex tube running down. My question is does anyone have a diagram of which line goes to which wheel? I can see on the top different color circles.
    Thanks.
    Kurt
  2. #2 Re: Front Passanger brake line
    Kurt...
    It kinda helps if you tell us what you are driving. Sorry..but it really does.
    I usually just follow the line and pop it out of the 4 holder clip down by the side of the trans, then find out which one it is going into the ABS. I don't remember the passenger side line ever having any flex in it. But there are some flex lines in that area. You can get around flex if you do a small coil.
  3. #3 Re: Front Passanger brake line
    you can follow the lines to where they go, or cut out the rusted line spot and replace it. use a flair tool, or compression fitting to re joint the lines.
  4. #4 Re: Front Passanger brake line
    I forgot to say.. Scott will be here soon
  5. #5 Re: Front Passanger brake line
    if your gonna be ninja ed, it may as well be from Bill.
  6. #6 Re: Front Passanger brake line
    Aug 2011
    Orland, Me
    Kurt...
    lol.. sorry about that. It's a 02 GTP.
    I'm thinking I might be a bit confused. To the brake lines all run to the ABS first?
  7. #7 Re: Front Passanger brake line
    2 lines from the master go to the abs, then 4 lines come off the abs. one of each line goes to a wheel.
  8. #8 Re: Front Passanger brake line
    Aug 2011
    Orland, Me
    Okay, then that's the info I was looking for. Does anyone have a pic or list of which (color dot) goes to which wheel? I believe I have followed the correct line up but I would rather be safe then sorry. I'm a little AR when it comes to having as much info as possible.
    Thanks
  9. #9 Re: Front Passanger brake line
    I never thought of it in that way. I like the idea.
    Sent a text to a GM tech buddy. He gets a lot of brake line work.
  10. #10 Re: Front Passanger brake line
    where did your line bust? and are you planning on changing the whole line? or just repairing it?
    maybe post a few pics of what your working with.
    like i said before the line are repairable by cutting out the bad section and replacing it. some times easier then changing the line.
    the line that runs across the rear sub frame on my car blew out, i ran a new 4 foot line in its place, cost like 20 bucks to fix.
    always cut the line in a area you can work in, so if you need to take more old line to get to a free area to work in thats always best.
  11. #11 Re: Front Passanger brake line
    He says there is nothing that tells us. Even GM ESI (factory manuals) don't tell us.
  12. #12 Re: Front Passanger brake line
    Personally..I have stopped using unions almost all the time on brake jobs. I've found NiCopp line the whole way is my preferred way. It bends by hand and is amazing stuff. Pricey..but you'll never touch it again.
  13. #13 Re: Front Passanger brake line
    thats the line i used, nice and soft, bends like butter. compression fittings are not the best choice but are cheap and do work.
    you know them coils in the rear frame bill? one side blew out, and the rest of the line was so rusted i was like f this line, just ran a new one across the back of the car. done deal.
  14. #14 Re: Front Passanger brake line
    That's what you are supposed to do Scott. They bolt the line to the top of the subframe.
  15. #15 Re: Front Passanger brake line
    seemed like the logical thing to do.
  16. #16 Re: Front Passanger brake line
    Aug 2011
    Orland, Me
    I am planning on running a new line the whole way. I also plan to use NiCopper line. I have no interest in doing it again. This line anyway. I'm surprised that people aren't all over the color dots.
  17. #17 Re: Front Passanger brake line
    It's too logical!
    However.. please report back on which dot is the front right when You find out.
  18. #18 Re: Front Passanger brake line
    Aug 2011
    Orland, Me
    I may even take a little extra time and track them all. I'll reply with the findings.
  19. #19 Re: Front Passanger brake line
    Awesome
  1. front brake line question
    By FordMan77 in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2013, 03:01 PM
  2. Replacing brake line - ABS module to right front wheel
    By SPECIAL EDITION in forum General Tech Discussion
    Last Post: 10-31-2011, 03:51 PM
  3. ss front brake line
    By 04BlackComp_G in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2011, 03:08 AM
  4. Front to rear brake line replacement - need advice
    By bxfl in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2010, 09:56 AM
