Thread: Fbody brakes and painting
Results 1 to 19 of 19
  1. #1 Fbody brakes and painting
    gardner,mass
    Im thinking ima upgrade to fbodys brakes concidering i can get calipers rotors and pads for 100$ brand new. i replaced my brakes all around last year and painted them. I got brand new calipers, cleaned them spotless and sanded them lightly, used 3 light coats of primer, high temp paint, and brake caliper clear. They look like **** now and chipped like crazy. So ima get these and repaint them. What shoudl i use that will hold up? Also what do you guys think about maby painting them a gloss black and getting green decals that say grand prix or gtp or something for them instead of all green like befor. Do i need to swap out my hoses to use the fbody calipers? And does anyone know what the banjo bolt thread is for them?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Fbody brakes and painting
    id get a set of SS brake lines for them, iirc you use the F body lines.
    as far as paint, i used vht caliper paint and nothing else front and backs. the backs looks like i painted them last week, but the f body fronts are dusty all the time, and a few chips from taking off the wheels and putting them back on. pretty sure they are like 3 years old, so if i need to repaint them so be it right?
    i have found if you spray wheel cleaner on the calipers they do clean up real nice. takes all the brake dust and dirt off.
  3. #3 Re: Fbody brakes and painting
    Feb 2010
    TN
    Or you could just go powder coat they wipe clean with a rag or even just when you wash the car
  4. #4 Re: Fbody brakes and painting
    id powdercoat them and call it a day.. And no to any type of decal.. Everyone knows what a Grand Prix looks like no need to advertise it on every single part.
    04 Comp G.
  5. #5 Re: Fbody brakes and painting
    only thing with powder coating is you need to rebuild the calipers, and the cost of the powder coating is way more then paint every 3 years.
    i do agree tho its the way to go if you dont mind the extra cost and the rebuilding of the calipers.
  6. #6 Re: Fbody brakes and painting
    Rebuild kits don't cost that much and sure beats having to constantly repaint your calipers. I wouldn't waste my powdercoating stock calipers but upgraded calipers like fbodies, brembos etc I would.
    04 Comp G.
  7. #7 Re: Fbody brakes and painting
    Hell all you really need is replacement seals, everything else you should be able to reuse if the calipers are brand new.
    04 Comp G.
  8. #8 Re: Fbody brakes and painting
    Feb 2010
    TN
    actually if the pistons are good redcomp is right, mine were good cost me 16.00 for new seal and rattle clips only thing I kept was pins and pistons and that was for the pair.
  9. #9 Re: Fbody brakes and painting
    And shouldn't cost to much to powdercoat especially a simple color like black.
    04 Comp G.
  10. #10 Re: Fbody brakes and painting
    Enfield, CT
    or this..... http://www.g2usa.com/
    It's epoxy paint for calipers and other car ****. Very durable but you can only use the paint in one sitting, in other words, you can't save half a can of the paint and re-use it 2 weeks later due to the fact that it's epoxy.
  11. #11 Fbody brakes and painting
    Blah powdercoating > g2
    What your going to spend on g2 I'm sure you could get them powdercoated for a tad more and never have to worry about it
    04 Comp G.
  12. #12 Re: Fbody brakes and painting
    gardner,mass
    Yea im not spending $100 on getting them painted or powder coated..... Has anyone used chassis saver or por? Honestly im guessing the primer i used was garbage hense why it chipped so much. I might try like a self etching and repaint them the same way i did.
  13. #13 Re: Fbody brakes and painting
    VHT cost like 15 bucks a can, one can did all 4 calipers.
    id let them hang where you painted them for about 3 days after painting them to let them cure/dry completely.
  14. #14 Re: Fbody brakes and painting
    gardner,mass
    The only thing that sucks is they dont have my green paint. Also do i really want to go another color? I was thinking black with the green lettering or green caliper/ black bracket. Idk im up in the air on that one. What does everyone think about color?
  15. #15 Re: Fbody brakes and painting
    Enfield, CT
    VHT Caliper Paint works very well too. Everyone IK that has used it, says to use a clear coat too BUT the most important thing to do is prep. Clean those calipers perfectly or take them to a machine shop and get them sandblasted.
  16. #16 Re: Fbody brakes and painting
    i sanded mine, then used duplicolor prep spray, did 2 light coats, then 2 more thicker coats.
    im sure the engine paint would also work if they have more colors that interest you.
  17. #17 Re: Fbody brakes and painting
    gardner,mass
    I used duplicolor engine paint for my green.
  18. #18 Re: Fbody brakes and painting
    http://www.vhtpaint.com/products/engineenamel/ they have ford green, not sure what that looks like.
  19. #19 Re: Fbody brakes and painting
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Grabber green might be close from dupi-color
    https://www.duplicolor.com/products/enginePaint/
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. WTB: FBODY brakes
    By stlmo_gtp in forum Wanted To Buy - Parts
    Last Post: 08-22-2014, 01:59 AM
  2. fbody brakes
    By WIgp02 in forum Brakes/Suspension/Chassis
    Last Post: 03-14-2013, 12:03 AM
  3. Need help with FBody brakes.
    By Sudden in forum Brakes/Suspension/Chassis
    Last Post: 08-14-2010, 03:16 PM
  4. Need help (Fbody Brakes)
    By 98GT3800 in forum Brakes/Suspension/Chassis
    Last Post: 01-14-2009, 05:38 PM
  5. longer SS brake lines (fbody brakes)
    By UR LOSN in forum Brakes/Suspension/Chassis
    Last Post: 03-30-2008, 02:38 PM
