Thread: Installing rear rotors
Results 1 to 6 of 6
  1. #1 Installing rear rotors
    Apr 2008
    Hello,
    Just wondering if somebody could point me to how to adjust the E-brake so I can install some new rear rotors. Already did the front. Started the back but then realized that the e-brake had to be adjusted to get the caliper on.
    2004 grand prix gt
  2. #2 Re: Installing rear rotors
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    There is a cog on the bottom of the e-brake drum to adjust them.
  3. #3 Re: Installing rear rotors
    Apr 2008
    When you say e-brake drum do you mean the rear of the caliper where the e-brake cable is connected and there is a spring.
  4. #4 Re: Installing rear rotors
    Las Cruces, NM
    You must have an 04+ ?
  5. #5 Re: Installing rear rotors
    SE Level Member alacran's Avatar
    Apr 2008
    Chicago, IL
    i think you are refering to the special tool that rotates the piston into the caliper. The tool is availble at any auto part store but i dont how to use it exactly. I just know that you need a tool that spins the piston back into the caliper.
    Dont quote me on that because i only worked on one car that had this and it did not work.
  6. #6 Re: Installing rear rotors
    Las Cruces, NM
    If it is an 04+ you'll need to rent the rear caliper piston tool from autozone. Is's really easy to use and turns the piston back into the caliper.
  1. Installing 6 1/2 Inch Front Speakers [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-28-2012, 11:45 PM
  2. How bad is it to run 12" rotors, Front & Back?
    By Incomudrox in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2008, 06:59 PM
  3. Centric pads and rotors. good?
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2008, 03:44 PM
  4. Storing supercharger rotors
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-27-2008, 07:25 AM
  5. Installing HUD?
    By retski420 in forum General Tech Discussion
    Last Post: 03-17-2008, 02:29 PM
