Thread: '04 N/A GP suspected bad ball joint
Results 1 to 12 of 12
  1. #1 '04 N/A GP suspected bad ball joint
    May 2012
    Bloomington, IN
    So I have an '04 with 176k and a suspected bad ball joint, at least as far as I can tell on the passenger side. Would it just be better for me to swap out the whole arm, maybe even both sides with the mileage, as I'm guessing if one is bad the other might not be too far behind. Let me know what you think, thanks.
  2. #2 Re: '04 N/A GP suspected bad ball joint
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Replace the whole LCA, I would do both as they are cheap. Can be had for 50ish each. Make sure to get an alignment after, also look into tie rod ends and sway bar end links and bushings in case they look bad while you are under the car.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: '04 N/A GP suspected bad ball joint
    Yea just swap the whole arm. You'll hate the effort you have to put into them just to replace the bushing on the existing one.
    04 Comp G.
  4. #4 Re: '04 N/A GP suspected bad ball joint
    Apr 2012
    Dayton, OH
    Unless the bolt seizes to the bushing then the job just got really fun.
    2012 F150 STX
  5. #5 Re: '04 N/A GP suspected bad ball joint
    Grinder + torch
    04 Comp G.
  6. #6 Re: '04 N/A GP suspected bad ball joint
    May 2012
    Bloomington, IN
    Does anyone know the size of the nut/bolts and the ball joint nut size, that would help, thanks.
  7. #7 Re: '04 N/A GP suspected bad ball joint
    pretty sure its a 18 mm for the ball joint, and the lca's iirc are 21 mm and a t 55 torx.
  8. #8 Re: '04 N/A GP suspected bad ball joint
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    You may want to go buy a cheap 18mm wrench w/ a box end that you can grind down so you can fit the box end in between the balljoint and cv axle. An open end wrench will strip the nut if the nut is really tight
    If you have access to a hydraulic press changing the ball joints out and not the whole arm isn't bad and saves yo a few bucks. But if you have to drill them out it can be a pain. I've done it twice. It's quite a royal PITA
    I went NA when a whore left -$300 in my bank account.
  9. #9 Re: '04 N/A GP suspected bad ball joint
    Apr 2012
    Dayton, OH
    I used an open end wrench without problems, broke it free with closed end, off rest of the way with the open end. I only almost broke the castle nut because I had the wrench up too far on it. You really just wanna worry about not rounded out the torx bolt.
    2012 F150 STX
  10. #10 Re: '04 N/A GP suspected bad ball joint
    May 2012
    Bloomington, IN
    What are the torque specifications to the ball joint and the mounting bolts on an '04 GP control arm if anyone can let me know, thanks.
  11. #11 Re: '04 N/A GP suspected bad ball joint
    Apr 2012
    Dayton, OH
    I just got them tight as I could
    Sent from the Milky Way
    2012 F150 STX
  12. #12 Re: '04 N/A GP suspected bad ball joint
    tight works well.
  1. How to get ball joint off and new one on
    By Bigheadedon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-09-2013, 03:07 PM
  2. 97 ball joint
    By jc71corvette2 in forum Introductions/Noob Questions
    Last Post: 10-02-2013, 11:25 AM
  3. Ball joint help
    By geetee in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2011, 05:23 PM
  4. Ball joint?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 04:59 PM
  5. Ball joint-What do ya think?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-25-2008, 11:32 AM
