Thread: How can you tell steering rack bad?
Results 1 to 5 of 5
  1. #1 How can you tell steering rack bad?
    Donating Users timboku's Avatar
    Montgomery, IL
    All suspension parts are less than a year old including outer tie rods done a week ago. Car was great until a few days ago it seems to wander at highway speeds. Also steering doesnt seem as tight as it should be at highway speeds. Checked everything no play in wheels when jacked up. Wheel bearings good as well. No leaks coming from boots I relasead clamp and looked. Rack is orginal with 220k on it. So probably needs to.ge done regaurdless. Also when I first start car and turn wheel feel a light grinding in the wheel but then it goes away. Finally if it is a rack saw on differnt site on using gxp rack? Seems like it would be the same. I have an 02 gtp. Maybe the magnasteer part is going out?
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  2. #2 Re: How can you tell steering rack bad?
    Mar 2014
    Indiana
    You have magnasteer? Sorry I've just been tryin to figure out if I do. Does your SPID have the magnasteer rpo code?
    2002 Fully Loaded GTP. Cat back exhaust and 20% window tint all the way around(Rollin in the dark). Soon to be CAI, headers, and high flow cat.
  3. #3 Re: How can you tell steering rack bad?
    Montgomery, IL
    Im not sure on the code but I have a wire coming.off thr rack which.means magnasteer. Usually gts and gtps 99+ have magnasteer.
  4. #4 Re: How can you tell steering rack bad?
    Mar 2014
    Indiana
    Ok. I need to replace my rack but haven't had time to check for the wires but I did find that my. 2002 gtp doesn't have the code but read that it could still have magnasteer
  5. #5 Re: How can you tell steering rack bad?
    Montgomery, IL
    Ya its easy to.see the wire..teying to find best deal on rack..ebay has ac delco rebuilt for 285 shipped...autozone has there junk for 200..idk.
  1. Steering rack
    By 98ctd in forum Brakes/Suspension/Chassis
    Last Post: 01-21-2014, 10:59 AM
  2. GXP steering rack issue
    By NorCalGXP in forum Brakes/Suspension/Chassis
    Last Post: 03-25-2013, 12:58 PM
  3. 98 with leaking steering rack
    By onlysr in forum Brakes/Suspension/Chassis
    Last Post: 01-22-2011, 12:03 AM
  4. steering rack
    By GTP Ryan in forum General Tech Discussion
    Last Post: 11-22-2010, 04:04 PM
  5. 97 GTP Steering Rack Replace
    By PolishedandWaxed in forum Brakes/Suspension/Chassis
    Last Post: 09-09-2009, 09:42 PM
