Thread: Comp G Swaybar bushing
Results 1 to 9 of 9
  1. #1 Comp G Swaybar bushing
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    Okay, so first I'm kind of searching a "clunk" in the front end of my 2004 GP Comp G and figured i would start at something cheap to start ruling out what it could be (and also freshening up the suspension). So im trying to figure out what the size of the sway bar is, everywhere it just shows the 3 different sizes and not specific. Ive been searching all over and nowhere says anything specific on the size or what size to get.
  2. #2 Re: Comp G Swaybar bushing
    Arizona
    19-20mm GM says 20mm though.
  3. #3 Re: Comp G Swaybar bushing
    i just changed mine last week, theres 3 sizes moog offers. i have a dorman 33 mm bar, but all they sell is standard sizes, you can do a test fit at the parts store to see if it fits the bar right. i had the Small one at first, and had to swap it for the middle sized one.
    so nice to not have the clunk anymore.
  4. #4 Re: Comp G Swaybar bushing
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Do you have access to a caliper? Easiest way to get an accurate measurement.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  5. #5 Re: Comp G Swaybar bushing
    Jan 2012
    New York
    Unfortunately i don't. Also what else in the suspension might cause a "clunk" i know it sounds dumb, just so i can check it all once.
  6. #6 Re: Comp G Swaybar bushing
    lca's and strut mounts will clunk too.
  7. #7 Re: Comp G Swaybar bushing
    Jan 2012
    New York
    SHould i just do all that (LCA, Strut mounts, Sway Bar bushings) at once? IS there any other bushings i might as well replace while in there? Also for the sway bar bushings and and other ones should i go with poly is there an advantage/disadvantage to it? Its' a daily driver with no mods and no plans to mod.
  8. #8 Re: Comp G Swaybar bushing
    poly should be just fine. i got the moog replacements, not poly but much firmer then the dorman crap that came with my bar.
    if your gonna do all that at once its best due to needing an alignment after your done.
  9. #9 Re: Comp G Swaybar bushing
    Jan 2012
    New York
    That's what i was going to do. i need new tires so i was thinking to do all this before i got them to align and balance everything.
  1. Swaybar Sizes
    By Odi in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2024, 05:51 AM
  2. Poly swaybar bushing torque specs
    By Gpmadness08 in forum General Grand Prix Discussion
    Last Post: 09-03-2013, 07:33 AM
  3. swaybar install
    By GTP GTP GTP in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2012, 05:34 PM
  4. Swaybar Brackets...
    Last Post: 11-13-2009, 01:07 PM
