Thread: Grand Prix wheel hub assembly ????
Page 5 of 5 FirstFirst ... 345
Results 81 to 84 of 84
  1. #81 Re: Grand Prix wheel hub assembly ????
    Jul 2013
    San Bernardino,Ca
    There are very few ppl on there that know what they're talking about, that list is very small though
  2. #82 Re: Grand Prix wheel hub assembly ????
    Enfield, CT
    IDK about all of this. I just clean the mating surface on the hub, the hole where the bearing sits in the knuckle, torque the hub bolts to 96 ft lbs with a little bit of blue loctite, and torqued the axle nuts to 151 ft lbs. That was on my 97 with SKF and had no issues. I put them on the gf's 02 later on and did the same procedure. For the 99+ it says to do 118 ft lbs for the axle nut but I did 151 ft lbs cause I knew it could take it. No issues with hers either.
    Sent from my LG G3
  3. #83 Re: Grand Prix wheel hub assembly ????
    Apr 2015
    NJ
    Nothing special about timken anymore unfortunately, like someone said previously, all made in china/taiwan/mexico parts now. I have had really good luck with mevotech in the past on previous cars, I am a big fan of how they over engineer their replacement bearings with larger internals for better load carrying capacity. Their ball joint boots are sometimes hit or miss but for the most part, nothing I havent had issues with with other brands as well. We recently installed a set of MOOG strut bearings on my buddies saab 9-3 and we couldnt figure out for the life of us what was causing the spring to bind and make noise after the replacement. When we pulled it all apart we found out that the included mounting bolts for the mount were actually a half inch longer then the OEM bolts, and were making contact with the spring when it turned. Fortunately I keep lots of OEM bolts around the garage and we were able to replace all of them without having to use hardware store parts. But its little **** like that that I keep running into with moog parts. Looked at my brand new control arms the other day that I pressed in moog spherical front CAB's into last month, and the dust boots had already separated from the housing leaving the ball joint exposed. I intend on contacting moog about that this week actually because im very disappointed.
  4. #84 Re: Grand Prix wheel hub assembly ????
    Hey now, I put a detroit axle bearing on my 06 sierra when I owned it.
    Drove that thing for like a year without a single issue and it only cost me 50 bucks LOL. I wouldn't even care if it lasted 1-2 years because a new SKF was like 150-170 IIRC from napa and even those have failure from time to time.
    Also I was being cheap and needed a bearing ASAP for cheap and ebay was my option.
  1. Hub Assembly/2000 Grand Prix Se
    By lewis1952 in forum Brakes/Suspension/Chassis
    Last Post: 10-10-2013, 07:03 PM
  2. Needed- WHOLE- dash assembly for a 2002 grand prix gt
    By mclifford in forum Introductions/Noob Questions
    Last Post: 03-20-2013, 09:04 PM
  3. How to Replace 96 Grand Prix HEadlight Assembly?! HELP!!
    By buckshotnc82 in forum Visual/Body Modifications
    Last Post: 05-28-2011, 03:55 AM
