Thread: Grand Prix wheel hub assembly ????
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 84
  1. #41 Grand Prix wheel hub assembly ????
    Not everyone has the money for Timkens. Remember that some folks have to do things on a budget. (Not saying that's the case with me because I've stuck with oem hubs but just as a point)
    04 Comp G.
  2. #42 Re: Grand Prix wheel hub assembly ????
    SWPA
    Trust me, I know about being on a budget. I would have loved to save money and get the $32 hubs, but I would have cussed like a sailor if I had to do the same repair job 2 months later because I was being cheap, so I just bucked up and spent the $100 on Moogs and just watched my cashflow for the next week or so.
  3. #43 Re: Grand Prix wheel hub assembly ????
    Enfield, CT
    Go with SKF, Timken, AC Delco/Raybestos.
    I went with SKF but only cause I got 50% when I worked at NAPA. I must say these are great bearings and they have the X-Tracker design which seems pretty sweet so far.
    The X-Tracker hub unit is designed by SKF to improve the performance, cornering and stability characteristics that race car and high performance vehicle owner's demand.
    The asymmetrical X-Tracker is a performance-engineered hub unit consisting of a double row angular contact ball bearing arrangement in which the outboard row has a larger diameter and contains more balls than the inboard row.
    This unique design increases the bearing load carrying capacity and operational life, while significantly improving camber stiffness compared to traditional symmetrical hub units. Improving camber stiffness allows the brake rotor to tilt less during vehicle cornering. This reduces brake caliper piston knock back, allowing the driver to brake later, and reducing lap times on the track.
    The small inner ring is retained with orbital forming which means the bearing will stay in preload under heavier loading, providing a longer service life.
    The X-Tracker is currently used in a number of high-volume, high-performance luxury vehicles and will retrofit a number of racing and high performance car.
    http://www.skf.com/group/industry-so...ker/index.html
    Moog/National is junk and so are the majority of the odd named eBay bearings
  4. #44 Re: Grand Prix wheel hub assembly ????
    I'll go with whtever I can get at advance and use a coupon code for and has some decent warranty
    04 Comp G.
  5. #45 Re: Grand Prix wheel hub assembly ????
    Enfield, CT
  6. #46 Re: Grand Prix wheel hub assembly ????
    SWPA
    Haven't had one issue with Moog and have only found positive reviews about them.
  7. #47 Re: Grand Prix wheel hub assembly ????
    SWPA
    Quote Originally Posted by HighOctaneRacing View Post
    Marketing hype,
  8. #48 Re: Grand Prix wheel hub assembly ????
    Unless that video contains boobs I'm not watching it
    04 Comp G.
  9. #49 Re: Grand Prix wheel hub assembly ????
    Donating User Odi's Avatar
    Chicago South Suburbs
    Marketing hype,
    May be, but SKF is actually a pretty damn good hub. Uncle used them on his GXP before he sold it.
  10. #50 Re: Grand Prix wheel hub assembly ????
    Enfield, CT
    this guy knows what's up. Timken is a great hub but SKF is great as well IMO
  11. #51 Re: Grand Prix wheel hub assembly ????
    Mercer, Pa
    I've had 4 Bonneville's over the last 10 years. I've had the same one for the last 8 years. It's pushing 208k miles running timken bearings. Yes timken made in Korea for the last 5 years.
    I only changed bad stock bearings with high miles and cheap bearings with less then 10k. Some less than 2k.
    People think our bearings are junk. The parts people buy are junk. Cheap parts are cheap for a reason. They have a 60 day warranty for a reason.
  12. #52 Re: Grand Prix wheel hub assembly ????
    SWPA
    Quote Originally Posted by sseilmnop View Post
    Exactly.
  13. #53 Re: Grand Prix wheel hub assembly ????
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Usually the speed sensor fails before the bearing makes bad noises. At least what I've noticed with stock ones.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  14. #54 Re: Grand Prix wheel hub assembly ????
    SWPA
    Haven't had any speed sensor issues, only a broken wire once.
  15. #55 Re: Grand Prix wheel hub assembly ????
    Jul 2010
    Coquitlam,BC,Canada
    I changed my left front last night; barely two years old, and SKF. Replaced with SKF again. Hopefully this one will last longer.
    Note to self..... buy a 36mm socket so you don't have to call your buddy and have him bring his over.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  16. #56 Re: Grand Prix wheel hub assembly ????
    SWPA
    Quote Originally Posted by Bronco Boy View Post
    I'm lucky. I already had a 36mm from taking the trans apart on my Stealth. LOL
  17. #57 Re: Grand Prix wheel hub assembly ????
    Arizona
    Unless someone pulls apart every brand bearing to show the "differences" everything is here say. Quality control on our bearings is so loose you don't know what you're getting anymore. So **** I'll stick with China **** hell at least it comes with new 10.9 grade bolts
  18. #58 Re: Grand Prix wheel hub assembly ????
    Lots of GM stuff is designed and made in Korea. Hell, the new Hyundai's/Kia's are made there and are pretty ****ing balling.
  19. #59 Re: Grand Prix wheel hub assembly ????
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    The guy with Detroit Axle mentioned that he put them in the rear, not the front. Failure rates on the rear are MUCH lower due to the lower stresses back there (not bearing the weight of the drivetrain/not dealing with the torque from the tranny), so they may be great in the rear (wow...that sounded bad...). I wouldn't mind putting cheapos in the back of the car, but for the front, I want something a bit more substantial.
  20. #60 Re: Grand Prix wheel hub assembly ????
    Dec 2010
    ATL,Georgia
    ^ this is a true statement.. i didn't even think about them being in the rear.. ya they are Def not taking a lot of stress that the fronts are.. good point... i guess I will see how long they last back there lol
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  1. Hub Assembly/2000 Grand Prix Se
    By lewis1952 in forum Brakes/Suspension/Chassis
    Last Post: 10-10-2013, 07:03 PM
  2. Needed- WHOLE- dash assembly for a 2002 grand prix gt
    By mclifford in forum Introductions/Noob Questions
    Last Post: 03-20-2013, 09:04 PM
  3. How to Replace 96 Grand Prix HEadlight Assembly?! HELP!!
    By buckshotnc82 in forum Visual/Body Modifications
    Last Post: 05-28-2011, 03:55 AM
