Thread: Camber Bolt question for Lowering springs
Results 1 to 7 of 7
  1. #1 Camber Bolt question for Lowering springs
    Jun 2013
    Metro Detroit
    Hey guys,
    I am about to purchase some camber bolts for my lowered GP but I have a quick question. I plan on going with the AC delco brand. When I had an alignment in the fall, my camber was showing -2.5 our on the rear left, and -2.2 on the rear right. Will I need 2 camber bolts per strut in the rear to bring this out. I don't know if there will be enough adjust-ability with just the 1 on top.
    Thanks.
  2. #2 Re: Camber Bolt question for Lowering springs
    You only need 1 camber bolt per side.
    If you can get it around -1.5 all around, thats pretty good.
    Slot the strut is the other option.
  3. #3 Re: Camber Bolt question for Lowering springs
    Jun 2013
    Metro Detroit
    Gotcha. I'll go with 1 per side. Will I notice a huge difference if they can bring me in to -1.5 all around, as opposed to centering me out at lets say -1.1-1.2?? My guess is probably not.
  4. #4 Re: Camber Bolt question for Lowering springs
    you won't notice the difference, but 2.5* is a lot for a daily driver when you don't need the clearance.
  5. #5 Re: Camber Bolt question for Lowering springs
    Jun 2013
    Metro Detroit
    Gotcha, and just for clarification, the camber bolt goes on top correct??? I've seen opinions from people on both top and bottom.
  6. #6 Re: Camber Bolt question for Lowering springs
    the top is the typical place for it to go, yes.
    but to be serious, you can use it on top or bottom because i know a few people that use two camber bolts in order to get more camber to fit their huge wheels.
  7. #7 Re: Camber Bolt question for Lowering springs
    Jun 2013
    Metro Detroit
    Okay. Thanks for the info, top it is!
  1. 05 Grand Prix Lowering Springs Question
    By Leroyy in forum Brakes/Suspension/Chassis
    Last Post: 10-06-2013, 11:20 AM
  2. Replies: 22
    Last Post: 12-07-2012, 12:06 AM
  3. Camber after lowering?
    By MyPrixGT06 in forum Brakes/Suspension/Chassis
    Last Post: 03-27-2012, 08:22 AM
  4. Rims and Lowering springs question
    By Dagujugrandprix08 in forum Tires & Wheels
    Last Post: 03-04-2009, 01:38 AM
