Thread: Coil Springs
Results 1 to 17 of 17
  1. #1 Coil Springs
    Aug 2012
    Iowa
    I'm replacing the suspension in my 05 Comp G and I'm finding everything I need except the coil springs. Rockauto has a few but they're all variable spring rate. I read somewhere that those are good for the back to reduce sag, but they also said to get constant spring rate for the front. Is this true or would I be just fine with the variable rate in the front and the back?
  2. #2 Re: Coil Springs
    Donating Users crock's Avatar
    Traverse City, Michigan
    I believe it all depends on what you are looking for in your ride. How do YOU want it to ride when you are done replacing the springs?
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  3. #3 Re: Coil Springs
    Aug 2012
    Iowa
    I'm more just looking for it to be a stock ride. It's a daily driver so I want it to be comfortable, but I don't want it to sit higher than stock normally does.
  4. #4 Re: Coil Springs
    If it was me I'll keep it simple and just get some low mileage stock springs
    04 Comp G.
  5. #5 Re: Coil Springs
    Aug 2012
    Iowa
    Do all 04-08 GPs have the same springs regardless of model or is there something specific I would be looking for?
  6. #6 Re: Coil Springs
    I believe they all share the same springs just different struts
    04 Comp G.
  7. #7 Re: Coil Springs
    Unless you plan on lowering it, why go with something different?
  8. #8 Re: Coil Springs
    Aug 2012
    Iowa
    Quote Originally Posted by crock View Post
    You make a good point
  9. #9 Re: Coil Springs
    Nov 2012
    Madison
    how many miles on your 05?
    If I was to do what you are doing I would toss the G springs back on.
    Are you spending the money on the FE3s that are stock on the compG?
    I mean if you want I can look at my old compg springs and get you the numbers, the tags are still on them.
    ____Ridin On Chrome posted this in an old thread____
    Front Springs:
    22133031 FKN Highest Rate
    22133030 FKJ compG
    22133029 FJT
    22133028 FJS stocker for 99gtp
    22133027 FJR Lowest Rate
    Rear Springs:
    10258880 TDJ Highest Rate come on 04+ comp handling package
    10258879 TDH
    10276574 TFY stock rate for my 99gtp
    10276573 TFW Lowest Rate
  10. #10 Re: Coil Springs
    Aug 2012
    Iowa
    My car has about 175,000 miles on it. It was suggested in another thread I started that I could get the Excel-G 339015 Front Struts (06+ Style, FE4 Spec) Excel-G 339148 Rear Struts (06+ Style, FE4 Spec) and be fine. So yes I am getting the struts for the special handling package.
  11. #11 Re: Coil Springs
    Good choice either the comp g or excel would be good for you. I stand corrected looks like you should find low mileage comp g springs.
    04 Comp G.
  12. #12 Re: Coil Springs
    Nov 2012
    Madison
    Quote Originally Posted by tachasmo View Post
    With a different sway and links.
  13. #13 Re: Coil Springs
    Aug 2012
    Iowa
    Quote Originally Posted by spazzz View Post
    So you're saying if I go with those struts I can't use the sway bar and stabilizer links for the 05?
  14. #14 Re: Coil Springs
    Nov 2012
    Madison
    Thats what I'm sayin.
    The front needs a swaparoo
  15. #15 Re: Coil Springs
    Arizona
    I thought Gxp springs were higher rate than comp g
  16. #16 Re: Coil Springs
    It could be ^ I have a set of both I'll compare the p/n
    04 Comp G.
  17. #17 Re: Coil Springs
    The excels would be excellent on that! What are you wanting to do with it?
  1. Coil Springs
    By crock in forum Wanted To Buy - Parts
    Last Post: 02-22-2014, 03:29 PM
  2. lowering springs or coil overs
    By lilmidge12 in forum Introductions/Noob Questions
    Last Post: 02-16-2013, 04:39 PM
  3. The dangers of replacing coil springs
    By trev0006 in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2013, 01:38 PM
  4. Anyone know about cutting a coil out of your springs
    By WERNE in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2010, 09:12 PM
