Thread: popping from right rear
Results 1 to 9 of 9
  1. #1 popping from right rear
    Aug 2012
    Sacramento
    I get a popping sound from the right rear of my car, I have replaced the rest struts and end links for the sway bay, was wondering what all else could cause that sound? Its not necessarily related to large bumps and is getting pretty consistent.
    Overkill Tune, Plog, 3"DP, 180*stat, Gutted Air Box, AL 605.
  2. #2 Re: popping from right rear
    Dec 2012
    Where 4T65E's were born
    Have you checked out the trailing arms and bushings? Also check the exhaust hangers to make sure the muffler isn't banging on something. Not much else that can make noise in the rear of the car.
    Sold.
  3. #3 Re: popping from right rear
    Aug 2012
    Sacramento
    Yeah I replaced the trailing arms with doorman units a year ago and they looked good. One of my lateral arms looks slightly bent. I'll replaced all 4 and see of that fixes it.
  4. #4 Re: popping from right rear
    Dec 2012
    I'm not sure if those can cause a popping sound but if it's bent it should be replaced and re-aligned. I know it may sound a bit obvious but check in the trunk for things that could be making the noise, epecially that may have fallen into the spare compartment and bounces around. Also what year GP do you drive? If the strut towers are rusted out they could make noise.
    Sold.
  5. #5 Re: popping from right rear
    Dec 2010
    ATL,Georgia
    Ya it could be the strut top mount making the noise... might be time to replace them and the struts
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  6. #6 Re: popping from right rear
    Dec 2012
    Well on the 97-00's (I believe those are the years) The strut tower which is part of the car, rusts and the strut may go through, and into the trunk. Newer models had further rust prevention methods and isn't as common.
    Sold.
  7. #7 Re: popping from right rear
    Aug 2012
    Sacramento
    Its an 01 and I am in northern California so there's no rust on the car except for the exhaust. I just replaced all 4 struts so it isn't the strut.
  8. #8 Re: popping from right rear
    Aug 2012
    Sacramento
    The more I listen to it the more it sounds like a bushing. I thought it was the strut mount and the struts where original but even after changing those out its still there. I did notice most of the aftermarket lateral arm upgrades have zerks, so considering the one that's bent is attached to the wheel that's making the noise I am optimistic that it is the cause. I didn't check them when the car was in the air for free play but OEM replacements are cheap enough.
  9. #9 Re: popping from right rear
    Aug 2012
    Sacramento
    Well replaced all 4of them and had it re aligned, it fixed it. The mechanic said the bushing on the bent one was waisted where they bolt up to the under side of the car. Explains why it sounded like it was coming from the trunk.
  1. popping noise from rear during acceleration GXP
    By atj8 in forum 5.3L V8 (LS4)
    Last Post: 03-28-2013, 04:09 PM
  2. Popping
    By Kolton Lock in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2012, 05:23 PM
  3. Popping noise in rear?? HELP
    By 3R1CD4V15 in forum Brakes/Suspension/Chassis
    Last Post: 01-18-2012, 01:56 PM
  4. Loud Popping noise from rear end.
    By Iceman1983 in forum General Tech Discussion
    Last Post: 06-09-2011, 11:14 PM
  5. Popping noise from the rear
    By tjhgtp86 in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2010, 11:29 PM
