Thread: Clunk...Clunk...Is driving me nuts!!!
Page 4 of 4 FirstFirst ... 234
Results 61 to 80 of 80
  1. #61 Re: Clunk...Clunk...Is driving me nuts!!!
    GT Level Member chamberlain198437's Avatar
    Grants Pass Oregon
    Silly question when you put the strut together with the spring did you use air on the nut or by hand? Did you use the old mounts? I would take a paint pen mark the nut on the strut, and the metal mount. Give it a few lights burps with the air gun and see if it moves.
    Sent from my LG-L38C using Tapatalk 2
  2. #62 Re: Clunk...Clunk...Is driving me nuts!!!
    HUDSON
    A couple things concerning clunks in the front of the car during braking, accelerating, turning, going over bumps that are over looked are: 1) the strut bars from core support to shock tower, 2) rack and pinion mounting bolts. I have had both of these be the results of clunks after exhaustive diagnosis of the front of the car searching for the noise. For the strut bars I loosened all the bolts and removed each bolt one at a time and cleaned the threads and lubed with anti-seize and then re-tightened. That solved my clunk shifting from forward to reverse that would make itself audible only sometimes. The next problem was a clunk when turning and driving over gutters along side paved roads and gas station ground fuel storage tank lids at gas stations.
  3. #63 Re: Clunk...Clunk...Is driving me nuts!!!
    Donating Users Burgundyman's Avatar
    Air was used on the nut. I installed a brand new mount. All parts used were OEM....Yeah, I know kinda of costly route...
    Quote Originally Posted by chamberlain198437 View Post
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  4. #64 Re: Clunk...Clunk...Is driving me nuts!!!
    Had not thought about Rack and Pinion mounting bolts. Are these bolts easily accessible?...I was thinking about sub frame bushings too?
    RED- 4 Door Sedan
  5. #65 Re: Clunk...Clunk...Is driving me nuts!!!
    the rack bolts are ok. they are not fun to get to.
    bad frame bushings could be the cause.
  6. #66 Re: Clunk...Clunk...Is driving me nuts!!!
    we checked out strut mount. everything is ok. Could the right Axle caused this problem too?...Noise is felt along floor pan. Coming from right side for sure.
    RED- 4 Door Sedan
  7. #67 Re: Clunk...Clunk...Is driving me nuts!!!
    axles tend to vibrate when bad. not so much a clunk.
    drop the back sub frame, its quick and easy enough to check the frame bushings.
  8. #68 Re: Clunk...Clunk...Is driving me nuts!!!
    I looked at the bushings at the rear as I did drop sub-frame to install sway bar bushings. They looked kinda looked worn but then again I am not sure if they were shoddy! I did notice that they were greased but I am not sure if the mechanic had done this to eliminate clunk awhile back.
    RED- 4 Door Sedan
  9. #69 Re: Clunk...Clunk...Is driving me nuts!!!
    Dec 2012
    Where 4T65E's were born
    If they're greased make sure they didn't loosen themselves up. We grease them at work because next time they may not come out.
    Sold.
  10. #70 Re: Clunk...Clunk...Is driving me nuts!!!
    Enfield, CT
    I've had a CV clunk on me but it only did that in reverse. When you installed the struts, did you loosen or take off the CV nut?
  11. #71 Re: Clunk...Clunk...Is driving me nuts!!!
    I torqued them to 85 foot lbs...
    RED- 4 Door Sedan
  12. #72 Re: Clunk...Clunk...Is driving me nuts!!!
    I am not sure. I had my GM mechanic friend do the work as I did not have a spring compressor and he was willing to help me.
    Quote Originally Posted by HighOctaneRacing View Post
    RED- 4 Door Sedan
  13. #73 Re: Clunk...Clunk...Is driving me nuts!!!
    Enfield, CT
    well if the nut wasn't loosened enough or taken off while removing and installing the strut, the CV may have overextended and one of the balls may have fallen out of the joint. Seen it happen twice in shops. Did the clunking happen shortly after the struts?
  14. #74 Re: Clunk...Clunk...Is driving me nuts!!!
    Yes...the clunking started after the struts were replaced. Initially, it was mild and I thought let the car settle and perhaps the noise will go away. It became more noticeable over time.
    RED- 4 Door Sedan
  15. #75 Re: Clunk...Clunk...Is driving me nuts!!!
    Check out your strut mounts. Pop the hood and shake the car as hard as you can see if there is movement.
  16. #76 Re: Clunk...Clunk...Is driving me nuts!!!
    Update...
    I replaced both CV axles which I bought from NAPA. Installed brand new control arms on both driver and passenger sides, installed new sway bar links and bushings. Definitely an improved ride, however the clunking noise is still there. Interestingly enough the clunking noise all but subsided when I drove it in the rain.
    RED- 4 Door Sedan
  17. #77 Re: Clunk...Clunk...Is driving me nuts!!!
    gardner,mass
    Ive been having similar issues. Only thing that hasnt been replaced it the subframe bushings but they look fine and the struts. Mounts were replaced with no effect.
    Although check if your balljoints are the bolt in style if they are try tightening them to the controll arm cus ive had issues with that.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  18. #78 Re: Clunk...Clunk...Is driving me nuts!!!
    Ball joints are bolted tight. My only other attempt is with subframe bushings...The struts looks fine...Shook them and they seemed intact.
    Quote Originally Posted by Ginseng View Post
    RED- 4 Door Sedan
  19. #79 Re: Clunk...Clunk...Is driving me nuts!!!
    Abilene, Texas
    Hey Burgundyman - Have you thought about the brakes? My brother's Firebird had loose caliper mounting bracket bolts that was making similar noises on teh driver's side -drove him nuts for 3 months.
    He brought it to me and I got lucky; I was actually checking for something else when I stumbles across the loose bolts. I hope this helps you.
  20. #80 Re: Clunk...Clunk...Is driving me nuts!!!
    My clunking goes away when it snows.
    Sent from A Galaxy Far Far Away........
  1. 07 Door Clunk
    By ltruax in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2013, 07:49 PM
  2. Mission for no more clunk
    By h0wl0ngcanitbe in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2013, 09:36 PM
  3. Guess my clunk???
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2012, 08:51 AM
  4. Front-End Clunk
    By xerxescct in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2010, 02:25 PM
  5. Crack pop clunk
    By Green97GTP in forum Brakes/Suspension/Chassis
    Last Post: 11-06-2009, 06:47 AM
