Thread: '05 Grand Prix steering feels like 1940 dump truck!!!
Results 1 to 7 of 7
  1. #1 '05 Grand Prix steering feels like 1940 dump truck!!!
    Nov 2012
    Toms River, NJ
    I've got an '05 Grand Prix and out of nowhere, my power steering failed. No noise, no leaks, nothing out of the ordinary except it feels like manual steering now. The pump is full and the fluid is not discolored or burnt. Not sure if there are any check valves that could be sticking or what. Any help would be great. Thanks.
  2. #2 Re: '05 Grand Prix steering feels like 1940 dump truck!!!
    Does it turn hard both ways?
  3. #3 Re: '05 Grand Prix steering feels like 1940 dump truck!!!
    Nov 2012
    Toms River, NJ
    Yes. Completely feels like pump failure, but as I said earlier, no leaks, noise, nothing.
  4. #4 Re: '05 Grand Prix steering feels like 1940 dump truck!!!
    well i guess **** happens sometimes.
  5. #5 Re: '05 Grand Prix steering feels like 1940 dump truck!!!
    Is the fluid moving?
    I know its hard to see back there, but is it being moved by the pump. A rare case is that the shaft inside as broke in two.
  6. #6 Re: '05 Grand Prix steering feels like 1940 dump truck!!!
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    when the shafts break on the trucks you can take the belt off and pull the pulley right out of the pump by hand.
    do you hear the pressure relief valve blow off when turned to the stops? It can only be the pump or the rack...pumps are cheap/racks expensive...so which one would you change first?
    2004 comp g
  7. #7 Re: '05 Grand Prix steering feels like 1940 dump truck!!!
    Nov 2012
    Toms River, NJ
    Got it. I'm gonna go pull the belt and check the pump shaft first, then move forward. Thanks to all of you!
  1. Stock 07 Grand Prix GT for 3/4 ton Truck of EQUAL value
    By pe4me in forum General Grand Prix Discussion
    Last Post: 03-13-2013, 02:58 PM
  2. Steering feels loose, but no play in wheels
    By Teancum in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2012, 01:26 AM
  3. Grand Prix feels heavy
    By mikedinthecity in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 08:31 PM
