Thread: Tie rod endlink and steering knuckle question
Results 1 to 8 of 8
  1. #1 Tie rod endlink and steering knuckle question
    Destroys cars izup69's Avatar
    Iowa
    Ok so maby a dumb question but whatever. When I replaced my endlinks a year ago on my 97 they did not seem to fit the knucle. For various reasons the car has been parked. I started to drive it again and the steering seems super loose on it. I checked it out and the endlink dose not fit snug into the knucle. As in with the bolt tighted down and the safty pin though the link I can move the endlink up and down quite a bit. It does not fit the taperd hole in the knuckle.
    Are their diffrent size link ends that will still fit the inner tie-rod link that may work ? Can I drill out and sleeve the knuckel for the endlink to fit properly? Or am I going to have to replace the hole steering knuckle. I dont want to do option #3 I plan on selling the car and dont want to spend the $300 for each knucle. But I will not sell it with the steering so messed up. (I'm not going to put someones life in danger).
    I plan on replaceing the endlinks soon since the rubber bushing has seemed to crack. But I dont want to have to buy 3-4 endlinks to find one that is the correct size.
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  2. #2 Re: Tie rod endlink and steering knuckle question
    Feb 2010
    TN
    Go with moogs and make sure that you check the following:
    Model GTP, GT, Se this must be correct
    Wheter or not car has magnasteer
  3. #3 Re: Tie rod endlink and steering knuckle question
    Iowa
    I have the moogs on there but like I said they do not fit. Stock for GTP dose not fit. Im dont want to spend $180 on endlinks and an alignment just so I can sell the car. Cheap ones work fine for me $20 bucks each vs $54 ill buy the $20 and punt the car. It is that stock tie-rod endlinks will not fit the car and I didnt know if a diffrent one had same diamiter inner connector but a larger outer to drop into the knuckle. Or if I could sleeve it and use a stock one or if I would have to replace the hole assebmly.
  4. #4 Re: Tie rod endlink and steering knuckle question
    It's not tight enough. I always zip them on with my impact so they get good and tight
  5. #5 Re: Tie rod endlink and steering knuckle question
    Iowa
    I cant even do that it is so loose that the threads stop short of it being tight. If it wasnt -45 with the wind chill I would jack it up and take a vid of what I am talking about.
  6. #6 Re: Tie rod endlink and steering knuckle question
    Just get a new one then and run it on with an impact
  7. #7 Re: Tie rod endlink and steering knuckle question
    Iowa
    Hopefully it warms up to like 5 above this weekend like it is suposed to then I can change them out.
  8. #8 Re: Tie rod endlink and steering knuckle question
    Jan 2021
    Ohio
    I know it's an old thread but for future reference, it sounds like he's talking about his spindle is wallered out.
    He needs to replace the steering knuckle, as the taper is wallowed out where the tie rod and taper snugs up into the steering knuckle.
  1. [?] steering column plastic / intermediate steering shaft question
    By localhost127 in forum General Tech Discussion
    Last Post: 06-10-2013, 08:33 PM
  2. Front Swaybar Endlink Question
    By ryepsboe in forum Brakes/Suspension/Chassis
    Last Post: 10-09-2012, 01:20 PM
  3. Steering Knuckle Replacement
    By bjornbjorn in forum General Tech Discussion
    Last Post: 10-24-2011, 06:20 PM
  4. New to forum - quick ball joint/knuckle question
    By jurtyhg in forum Introductions/Noob Questions
    Last Post: 07-11-2011, 07:23 PM
  5. 04 CompG endlink size
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 07-08-2008, 08:15 PM
