I am about to snag some zzp front/rear STBs off an 00 impala... will these fit my 02 GP? Checked on zzps site but they didn specify for that year.
Thanks!
Thanks!
Should fit considering its basically the same car
If all else fails you could probably sell them on here anyways
Should fit any gen 2/3 w body
My 97-03 bars wouldn't fit the 04+ in the rear worst case you'll have to grind out the holes a little
Ls4 need clearance at the alternator I think but mine from my 98 fit my comp g no problem
Mine fit fine. Pulled them off the 98 before I scrapped it and threw them on the 04 with no problem. What problem did you have?
Holes didn't line up needed a half inch to slot or it to fit so I just sold them and built m own eventually
