Thread: Rear parking brake
Results 1 to 13 of 13
  1. #1 Rear parking brake
    Mar 2013
    Canada
    My right rear brakes are making this weird noise whenever I'm coming to a stop, All new pads and rotors were installed not even a year ago and I'm sure I need to adjust the parking brake, anybody know how to adjust the parking brake on pads on a GP 2008, is the adjustment on the calliper itself? I know how to do shoes but never done them on brake pads. Thanks
  2. #2 Re: Rear parking brake
    dont think you can adjust the e brake on the 04+.
    id take the back wheel off and check the pads out, newer cars use more back brakes then older cars, if cheap pads were used they could be down to metal on metal. if the rotors have deep grooves in them good chance the pads are worn out.
    while your there, make sure the backing plate is clear of the rotor they can get bent a little and then rub the rotor as it spins.
  3. #3 Re: Rear parking brake
    Portland Oregon
    Did you make sure to screw the piston back in all the way when you put the pads on the rear? If you did then you're fine
  4. #4 Re: Rear parking brake
    Mar 2013
    Canada
    Of course when I replaced all my pads and rotors all around I made sure the piston is in all the way, however yesterday I decided to take another look at the rear and front and I notice this at the rear, I think I found the sound that happens whenever I go over speed bumps and a dimp in the road, it turns out that the ebrake cable was hitting the gas tank and also hitting another bar, so I ended up using dishwasher rubber hose and wrap it around bar might be the control arm. Here are some pics https://www.dropbox.com/s/ky30zowzg6...012_105753.jpg https://www.dropbox.com/s/37tw02cowi...012_105758.jpg
    With the front as indicated I do hear this sound when im applying the brakes and come to a complete stop and then let go and apply again I hear this pop/grinding noise, I re-lubed the pads and the pins and still same issue, however I notice the outer tie rods had grease leaking out which is common when I first replaced them in May but now they were still grease around it, I was able to insert my finger in the rubber and trying to see if any-more grease comes out but it didnt so either it has no more grease left and thats the noise im hearing when I apply the brakes slowly. Here is a video let me know what you guys think
    Front Driver side
    https://www.dropbox.com/s/lj3yr43w1q...005_093537.mp4
    https://www.dropbox.com/s/gelvin5ez7...005_092510.mp4
    This is the rear side as you can see there was grease around the rubber when I first looked at it
    https://www.dropbox.com/s/ijmfmanbuz...005_094606.mp4
  5. #5 Re: Rear parking brake
    why in the world are you jamming your fingers into the dust boot there?
    re grease your tie rod end, that what the nipple on the top is for, (use a grease gun) new grease will come out the boot, when you see the grease start to come out, its greased, and your done, stop greasing it.
    then put the wheel back on, lugs tight, wheel jacked up still, then grab the wheel at the 3 and 9 o clock areas, push one side and pull the other, and back and fourth, if it moves the tie rod is bad. you can watch the tie rod when you do this to confirm its moving.
  6. #6 Re: Rear parking brake
    Mar 2013
    Canada
    Will do, do you think the seal is broken?
  7. #7 Re: Rear parking brake
    Quote Originally Posted by ibra0078 View Post
    on the tie rod end that you fingered? its fine as long as its not ripped, when you grease it, it will puff back up.
  8. #8 Re: Rear parking brake
    Mar 2013
    Canada
    Okay I got to go pick up a grease gun as my friend was the one who filled it up does all grease gun comes with the right adapter to fit the nipple?
  9. #9 Re: Rear parking brake
    yeah its a standard fitting.
    harbor freight has guns for 10 bucks,( grease tubes are like 3 bucks) the nicer one is 15. get one with a hose on the end. they are easier to get into tight spaces, and the one with a metal tube can break if your not careful storing it or if dropped and so on.
    oh canada, not sure if you got the good old HF. but a gun should be in that range, 10 to 20.
  10. #10 Re: Rear parking brake
    Mar 2013
    Canada
    Princess auto has this cheapest one that has a flex hose http://www.princessauto.com/pal/en/G...-Gun/8084063.p or might pick this up http://m.canadiantire.ca/mt/www.cana....jsp?locale=en and you said no special adapter is required right
  11. #11 Re: Rear parking brake
    thats what you want. but 30 bucks sucks, HF sells the same one or its style for 15.
    if you can find a cheaper one, most of them you can take the metal tube off and put a hose on in its place, it just threads in. but that plan only works if the hose part is cheaper when you add the metal tube gun and the price of the rubber tube up, if its less then the 30 it would be a better deal.
  12. #12 Re: Rear parking brake
    Mar 2013
    Canada
    Okay will see what I can find, any grease tube is fine right? Thanks for your help
  13. #13 Re: Rear parking brake
    yeah, the tubes are universal, all the same threads on the ends, it should be. they always worked for me, done it 3 times over the years.
    back in the day the hose was a option you added, now they sell them with the hose or a metal tube.
  1. Putting the parking brake cable on the rear caliper
    By Fahrenheit in forum Brakes/Suspension/Chassis
    Last Post: 10-09-2013, 03:32 PM
  2. Parking Brake issues
    By fromne in forum Brakes/Suspension/Chassis
    Last Post: 09-16-2013, 10:31 PM
  3. Hung up rear calipar with a "pop" in the parking brake
    By Buggsy in forum Brakes/Suspension/Chassis
    Last Post: 12-30-2012, 09:04 PM
  4. parking brake adjustment
    By CMURDAx in forum General Tech Discussion
    Last Post: 12-29-2009, 08:04 AM
  5. Parking brake adjustment
    By ROTTMAN in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 10:35 PM
