Thread: Emergency brake uses fluid?
Results 1 to 13 of 13
  1. #1 Emergency brake uses fluid?
    Nov 2010
    White Lake, MI
    I have a 2005 Grand Prix N/A and have a brake fluid leak in the rear passenger side.
    I have briefly checked it out and see it runnig all the way down the tire.
    I have been using the emergency brake to park to not put a toll on The transmission.
    Before I inspect where it is coming from was wondering if the emergency brake even uses brake fluid?
    Or is is mechanically operated with a spring?
    Thanks
    2005 Pontiac Grand Prix, Base, 3800, N/A
  2. #2 Re: Emergency brake uses fluid?
    the e brake is all cable, you have a leak in the line or the caliper in that back tire.
  3. #3 Re: Emergency brake uses fluid?
    What he said
  4. #4 Re: Emergency brake uses fluid?
    Nov 2010
    White Lake, MI
    Thank you will check it out!
  5. #5 Re: Emergency brake uses fluid?
    Nov 2010
    White Lake, MI
    So here is what I found.
    It look to be where the emergency brake links up to the caliper? What part is actually leaking? Do I need to replace the whole caliper?
    Red Arrow is where it is dripping from and green circle is where fluid is showing.
    Lines look to be bone dry.
    http://
    Fluid only seen in the area
    http://
    Dripping Here
    http://
  6. #6 Re: Emergency brake uses fluid?
    Have some one pump the pedal and keep looking around for a leak
  7. #7 Re: Emergency brake uses fluid?
    SE Level Member stealth06's Avatar
    Dec 2012
    New York
    I have the same leak and a new caliper ready to go in. According to the factory service manual when the caliper leaks fluid there it is time for a new one. If I get mine done in the near future I will post some pics. It does involve taking the tension off of the e-brake cable and disconnecting it further up. Then, you can disconnect it from the caliper.
  8. #8 Re: Emergency brake uses fluid?
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    i think that might actually be muffler fluid.
  9. #9 Re: Emergency brake uses fluid?
    Nov 2010
    White Lake, MI
    Quote Originally Posted by stealth06 View Post
    Where do you disconnect to take the tension of the e-brake? Do I need a special tool?
    I have everything off, just cannot get the emergency brake cable off the caliper.
  10. #10 Re: Emergency brake uses fluid?
    At the caliper I believe
  11. #11 Re: Emergency brake uses fluid?
    Kansas
    I found Amazon to be the best for an ACDelco brand with no core charge. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    As someone stated that is a non-serviceable part so replacement is the only option. I just replaced both of my rear calipers about 6 months ago. As for removing the cable from the caliper itself I believe we used a big ass flat screwdriver and pliers.
  12. #12 Re: Emergency brake uses fluid?
    Nov 2010
    White Lake, MI
    Quote Originally Posted by NegativeOne13 View Post
    Just got it done, went with my local parts store $85.00 without core. Used large channel locks and compressed the parking break spring to remove cable and the same for installation.
    Only thing now it the park brake is weak and needs to be adjusted it seems. Anyone know how to adjust the e-brake?
  13. #13 Re: Emergency brake uses fluid?
    Nov 2010
    White Lake, MI
    So figured out I didn't need to adjust the e-brake line. Just had to bleed it properly with the cap on and not off.
  1. Emergency brake light always on
    By 99gtpguy in forum General Tech Discussion
    Last Post: 05-14-2013, 07:41 AM
  2. Seized Emergency Brake, NoIcon Displayed
    By grandprixgtp2001 in forum Brakes/Suspension/Chassis
    Last Post: 12-23-2011, 10:49 AM
  3. Remount Emergency Brake
    By 96GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2010, 09:50 PM
  4. brake fluid
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2009, 06:51 PM
  5. Emergency brake gone
    By BlackJack in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 08:49 PM
