Thread: 02 Impala steering issue
Results 1 to 5 of 5
  1. #1 02 Impala steering issue
    St. Louis
    Just got a call from a buddy with an 02 Imp. Let me preface this with the fact that it was involved in a hit and run on the pass. side recently, to the point where it sheared 2 wheel studs off the hub.
    He said that when he turns (didn't say which direction) that he feels something give, and then the steering turns a bit more. He's bringing it over tomorrow for me to take a look so I figured I'd get some input on what to check out.
    My thoughts are:
    Bent outer and/or inner tie-rod or a damaged rack.
    Your thought's??
  2. #2 Re: 02 Impala steering issue
    Everything on that side is suspect.
    CV could be dinged up, strut may be bent, control arm bushings might be gone, subframe bent.. name it.
  3. #3 Re: 02 Impala steering issue
    St. Louis
    So basically what you're saying is wait until tonight when I can get it up on a jack and some stands and take a look, lol.. I guess I'll know shortly. Thanks Bill!
  4. #4 Re: 02 Impala steering issue
    St. Louis
    Well, for resolution here's what I found and replaced today:
    Cracked swaybar on drivers side. New Dorman solid bar in it's place.
    Bent pass. side strut. Replaced both sides w/ new quick strut assemblies
    Pass. side ball joint was about to come apart. Not sure what was holding it in really. Installed new Dorman arm w/ball joint.
    End result- no more popping noise and the steering is nice a smooth again. Probably has less body roll now with the new bar, lol...
  5. #5 Re: 02 Impala steering issue
    There ya go.
  1. Steering issue?
    By nickgpgt in forum General Tech Discussion
    Last Post: 04-15-2013, 11:33 PM
  2. Power Steering Issue
    By cp93 in forum General Tech Discussion
    Last Post: 04-13-2012, 09:01 PM
  3. steering issue
    By macjns25 in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2011, 01:17 PM
  4. power steering issue
    By tstaller2005 in forum General Tech Discussion
    Last Post: 04-27-2011, 10:05 PM
  5. Power Steering Issue?
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2009, 04:09 PM
