Thread: Proportioning valve question
Results 1 to 1 of 1
  1. #1 Proportioning valve question
    Dec 2012
    Where 4T65E's were born
    I'm thinking of completely replacing my brake lines in the spring since they're getting kind of bad in spots, not horrible but there are also compression fittings in places from previous owner's fixes. I'm doing pads and rotors as well, and I want my brakes to be in the best shape possible. As of now I have a leak at the proportioning valve [#10289556] on the left side. I believe it's leaking at the flared fitting from the fixed line, it may need tightening or something but it's also corroded and they're known to leak from the seam. I'll be replacing them as well. The question is, does it matter at what point in the line the proportioning valve is? From the factory they're right before the caliper, which means the aluminum housing is exposed to all the salt in the winter here. I'd like to know if when I replace my entire line, (I have to cut the line to put it somewhere anyway) Can I put it right after the ABS module or some point down the firewall, instead of under the floorboards? It will still be in the same line just closer to the master cylinder. I heard that it's either there or built in to the abs module on the 04+ GP's.
    Sold.
  1. Rear proportioning valves 1998
    By transam24 in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2013, 12:41 PM
  2. Proportioning valve upgrade
    By Logan541 in forum Brakes/Suspension/Chassis
    Last Post: 05-12-2013, 06:49 PM
  3. EGR valve question
    By GTLGDP in forum General Tech Discussion
    Last Post: 02-27-2012, 10:01 AM
  4. Leaking hydraulics - proportioning valve
    By SJAndrew in forum Brakes/Suspension/Chassis
    Last Post: 10-20-2011, 01:51 PM
  5. proportioning valve replacement
    By Spartanzz in forum Brakes/Suspension/Chassis
    Last Post: 07-18-2011, 11:08 AM
