they go through camber change when the suspension compresses. :)
looks like a good start to a nice spherical bearing upper mount. using rubber/poly as your flex joint is always silly.
you ge tthe ebay junk yet?
Yea sure did the plate is about a half inch in diameter to small to use for our cars so I have to return them and find another solution
well ****, just redrill 2 holes and use one oem
Could weld tabs but I don't want that kind of worry
Looks like if you can exchange them for a slightly bigger one overall then do some trimming if needed then it could work.
cut out the middle of the OEM plates and bolt that to the OEM plate
Nope that's the absolute biggest they have. I asked the rep already.. So freaking close too.
I've thought about it. But it would probably take away from the either the OEM plate or the camber plates strength.
Here are more pics for reference
http://i.imgur.com/y5I8vb4.jpg
http://i.imgur.com/Mc2xL3b.jpg
Hmm I'll have to look more at it when I get on the computer.. Maybe just have to go another route and buy a bigger one from another seller then cut and trim if needed..
Yea maybe cut out the middle.. Trim the plate just a tad bit around where the studs would go and then weld the plates together.
you just drill the oem plate and countersink it a little for some flush head bolts.
keep in mind the weight is all gravity, and cornering loads are at the end of a long lever (no leverage)
i just know that the oem strut tower has plenty of meat for you to drill 3 or 4 new holes closer to the strut centerline (within the dia of that plate)
Well as usual your right , on my to return these to the post office and decided to see if the strut tower had the clearnence. A detail that I never thought of for some reason. I can utilize a 4 bolt setup for the plate to body and drill the stb brace but leave it as is. Should be a super strong setup.
http://i.imgur.com/hb4ieFh.jpg
The stack will look like this. I'm pretty excited now
Now I just need to get my measurements symmetrical and drill.
http://i.imgur.com/0IDTAGx.jpg
quit bein a pessimistic ***** communist and get it done
Heres the deal on the plates, measuring is key, everything else will be plug in play for asny shock we currently use, the universal camber plate comes with bushings already, all that is required id drilling the threaded one out till there are no threads and the factory nut goes on top.
The great thing now is that the thrust bearings can go up top on the spring hats, when i find time in the future ill order another set of thrust bearings and put them on bottom as well.
http://i.imgur.com/n7OpoAW.jpg
http://i.imgur.com/WVqT6sF.jpg
you then end up like this, I would highly recomend helper springs or going back to 12" springs.
http://i.imgur.com/FPXq9bM.jpg
If i could do it over again i would have made a template, which i still probably do of the factory mount and had that cut out on some aluminum plate and bolted it all together for more contact surface on the strut tower
http://i.imgur.com/gmHTa4y.jpg
it would be real easy for me to water jet that out of aluminum
O really now??
yeah till ya s*** a brick at the cost of the material
