Thread: Bilstein Coilovers
Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 145
  1. #81 Re: Bilstein Coilovers
    hangover park IL
    a walk through a junkyard with a ruler will give you cars with similar uper dimentions
    ~James~ Psychotic Gearhead
  2. #82 Re: Bilstein Coilovers
    Arizona
    I'm so pissed I didn't see this last week I might just order those anyway. These slots have always made me paranoid though. The thought of a plate being held by tension from bolts seems like it would slip
  3. #83 Re: Bilstein Coilovers
    Order them lol... You'll get them done faster then I will.
    04 Comp G.
  4. #84 Re: Bilstein Coilovers
    those universal camber plates are a great idea! it'd be suuuuper easy to put a few studs in them and have them on your car shortly after. now if only there was a coilover body that was worth using, heh.
    and as far as the alignment slipping, when the upper mount is under tension from the suspension it's almost impossible for them to slip.
  5. #85 Re: Bilstein Coilovers
    Howell, NJ
    I really need to make new top mounts for my set up.
  6. #86 Re: Bilstein Coilovers
    only the fronts would be helpful for you.
    either way slotting the struts you have now would be an easier solution. and give you more flexibility since you're just looking for a camber increase to fit those wheels.
  7. #87 Re: Bilstein Coilovers
    Howell, NJ
    I don't really need any more camber adjustment .
    I just want something that's stronger, better looking and something that fits better.
    Here's what I have now ( the bolts aren't tightened )
  8. #88 Re: Bilstein Coilovers
  9. #89 Re: Bilstein Coilovers
    Arizona
    There on order. I'll have pics up when they arrive main reason I want them is so the primary turning action isn't just on the thrust bearings, it will also be on the upper bearing.
  10. #90 Re: Bilstein Coilovers
    Howell, NJ
    Nope that's how they are.
    The washers actually touch the lip of the strut tower. And I don't like that either.
    My rears are a different story.
  11. #91 Re: Bilstein Coilovers
  12. #92 Re: Bilstein Coilovers
    Arizona
    Quote Originally Posted by Jomamma View Post
    Why did you make them like that. You could have got more travel with a bump cup upside down like mine
  13. #93 Re: Bilstein Coilovers
    Quote Originally Posted by 91parkave View Post
    Yay
    Keep us updated like I'm sure you will!
    04 Comp G.
  14. #94 Re: Bilstein Coilovers
    Dec 2010
    ATL,Georgia
    91parkave.. he's on bags lol I think he's got plenty of travel ;-)... but ya that's how mine look as well they are touching the strut tower
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  15. #95 Re: Bilstein Coilovers
    Howell, NJ
    I didn't make them.
    I don't think anymore strut travel would help, my struts are pretty short.
    Instead I think I'd have to worry about over extending the strut first if I were to run higher bag pressure.
  16. #96 Re: Bilstein Coilovers
    Arizona
    Wasn't tracking the bags
  17. #97 Re: Bilstein Coilovers
    hangover park IL
    "any suspension can be made to work if you keep it from moving"
  18. #98 Re: Bilstein Coilovers
    Arizona
    A little disappointment as summit forgot the bearings. But I did get the cups..essentially you can have a spherical bearing setup and still use a burned out mount.and of course some minor welding but the tradeoff is far more reliable and better than the crap weve been using for coilovers on wbodies. Here are some pics.
  19. #99 Re: Bilstein Coilovers
    I live here. DirtDog's Avatar
    Jun 2012
    Those for the fronts and rears
  20. #100 Re: Bilstein Coilovers
    Arizona
    Front.. No need for the rears...as they don't actively go through camber changes or turn.
  1. Given up on coilovers
    By carcrobatics in forum Brakes/Suspension/Chassis
    Last Post: 06-10-2013, 12:33 AM
  2. Bilstein HD?
    By Akuch26 in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2013, 10:07 AM
  3. Bilstein Rear Struts...
    By Alsafi92 in forum Wanted To Trade
    Last Post: 01-29-2013, 04:11 PM
  4. agx vs bilstein
    By 06PONTGP in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2012, 08:59 PM
  5. Bilstein offered for 97-03??
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2010, 10:30 AM
