Re: Went to Les Schwab for an alignment.... need your guys help
Well only 3 reasons to replace a hub. 1. Wheel speed sensor problems, 2. Play in the hub, 3. Noise from the hub.
If theres no noise or speed sensor issues, pull on the wheel with it jacked up to check for play. If there's none then it's fine.
02NavyBlue
Thanks for that ill put it up in the air and check, as it stands there is no noise or speed sensor issues.
h0wl0ngcanitbe
Super easy to change hubs search the how to's , and BTW cover up you phone number next time :)
This place sounds like Tires Plus, took my black car in to get some tires they come out with a ~$1600 list of things that need to be replaced, 2 lower control arms for $250 each 2 tie rod ends $180 each $426 for the tires plus ~$400 for labor. But the alignment was free with the purchase of the tires. I told them no, priced out all the parts for less than what they wanted to charge me for labor.
slick2500
Heh im a licensed Realtor, my numbers everywhere!
^what?
Sent from my LGL75C using Tapatalk 2
slick2500
^what?
Im self employed and run a large youtube business, my phone number is everywhere on the internet! I dont mind my number floating around I get a lot of calls.
