Thread: Coilovers / Spring Rates - Need Advice!
Results 1 to 20 of 40
  1. #1 Coilovers / Spring Rates - Need Advice!
    GT Level Member carcrobatics's Avatar
    Dec 2012
    California
    Hello all, I'm about to bite the bullet on some coilovers for the FRONT ONLY. Reason being my B+G Spring + KYB AGX setup has a bit of sag in the rear. To be specific, I have a two finger gap in the front and one finger in the back. This picture below shows the difference pretty well. If you have trouble seeing you can zoom into your browser window by holding down the control button and scrolling at the same time, though I'm not sure that works on all browsers/computers.
    So basically I'm going to drop the front down to a one finger gap to match the rear perfectly. I've never been on coils in these cars and I'm not sure what spring rate I should be running for this low of a drop. I know most people run 350# and higher to avoid bottoming out all the time, but I'm not sure how low they run their cars or what struts they use either. I'll be going with KYB AGX struts, and I'll probably be running them on the stiffest dampening setting at all times like I am now. Since I am only doing the front, I want to go as low as possible on the spring rate to match my B+G rear spring rate as well as possible for more even handling vs having understeer everywhere. Any and all advice is welcome. I know these cars aren't incredible in the handling aspect so you don't have to tell me that, if I have to run a high spring rate I'll probably just get a real stiff rear sway bar to even it out as much as I can.
    '00 GT - Build Thread: XXX - SOLD
    '93 Miata - Drift Project
  2. #2 Re: Coilovers / Spring Rates - Need Advice!
  3. #3 Re: Coilovers / Spring Rates - Need Advice!
    Dec 2012
    California
    it'd be easier just to cut the front spring a little.
    you're probably the last person I'd expect to say that hahahaha
  4. #4 Re: Coilovers / Spring Rates - Need Advice!
    GTX Level Member blackflag's Avatar
    Virginia
    i would get gr-2 with something a little heavier than 350. at 350 you will still bottom out ALL the TIME
  5. #5 Re: Coilovers / Spring Rates - Need Advice!
    Nov 2011
    NY
    The larger problem will still be the mismatch between the coil spring rate and the dampening rate of the strut... They need to be matched in order to work correctly. In other words, the GR-2's are not the answer. It may work for a little bit, but will wear out and leave you wanting more... Proper investment in coilovers and matched struts will run ya around a grand for the front alone.
  6. #6 Re: Coilovers / Spring Rates - Need Advice!
    Dec 2012
    California
    Quote Originally Posted by BlackFlag View Post
    What springs/struts are you running? And how low are you?
  7. #7 Re: Coilovers / Spring Rates - Need Advice!
    Dec 2012
    California
    Like I said I'm not going with GR-2's.... Stock struts have no place on coilovers.
  8. #8 Re: Coilovers / Spring Rates - Need Advice!
    Virginia
    Quote Originally Posted by carcrobatics View Post
    350# with gr-2s.
    i have a .5" fender gap.
    Agxs are known to blow just as fast as gr-2s. THAT is why i wont spend the money
  9. #9 Re: Coilovers / Spring Rates - Need Advice!
    Yea you might want to do some research AGX blow out just as quick.
    04 Comp G.
  10. #10 Re: Coilovers / Spring Rates - Need Advice!
    Nov 2011
    NY
    What are your expectations of the GR-2's? You do know they're only a slight upgrade over stock... Do you honestly think $120 struts are going to perform?
    If your are serious about wanting coilovers you should be looking at MonoTube struts like Bilstiens and having them valved to match the rate of the springs. You'll still have another issue that the height of the strut rod will be too tall as you're using lowered springs lol... But you wanna gangster the ride, go ahead, it'll still work... Lol, but don't think that GR-2's and a stiffer rear sway will fix anything. Sorry : )
  11. #11 Re: Coilovers / Spring Rates - Need Advice!
    Arizona
    I'd say most people blow the struts because of the compressed strut travel once you press hard enough on the lower limit of rod stroke it will blow the strut quickly.
    The bisteins had way more to work with in stock form as far as rod length being shorter. They are still holding up with my 350# setup.
  12. #12 Re: Coilovers / Spring Rates - Need Advice!
    Dec 2012
    California
    Quote Originally Posted by 91parkave View Post
    Could you link me to the struts you're talking about?
  13. #13 Re: Coilovers / Spring Rates - Need Advice!
    Dec 2012
    California
    Quote Originally Posted by coolone View Post
    For the last time, I'm not running gr2's...
  14. #14 Re: Coilovers / Spring Rates - Need Advice!
    Dec 2012
    California
    My agx's are holding up real good so far, maybe i got lucky.
  15. #15 Re: Coilovers / Spring Rates - Need Advice!
    Virginia
    although you are right, that would require a ridiculous amount of money.
  16. #16 Re: Coilovers / Spring Rates - Need Advice!
    Dec 2012
    California
    350# with gr-2s.
    Besides the obvious difference in cost, don't the agx's handle the springs better?
    I'll be lowered at a 1in gap. But that probably doesn't matter too much.
  17. #17 Re: Coilovers / Spring Rates - Need Advice!
    Virginia
    I can't say. I'm happy with my ride though.
  18. #18 Re: Coilovers / Spring Rates - Need Advice!
    Arizona
    Shaved HD bilsteins
  19. #19 Re: Coilovers / Spring Rates - Need Advice!
    Nov 2011
    NY
    Bilstein Shocks for a 2000 PONTIAC Grand Prix including GXP
    the Sport version...
    sorry about the GR-2's reference! Lol
  20. #20 Re: Coilovers / Spring Rates - Need Advice!
    That site is wrong.
    Bilstein does not sell B8's for the W body.
    They sell comfort and heavy duty valving B6's.
    B8 is designed for lowering springs, typically work well with the H&R springs. Namely they have a slightly shorter rod, say 20-40 mm.
    If you're serious about Bilstein coilovers, fill out this form: Fat Cat Motorsports - Consultation form, new monotube suspension, shocks and coilovers
    But note it's going to cost you $50 for consultation, and the coilovers will be somewhere around 2500. Maybe.
    I bought KYB Sports for my car, I really hate them. I'm contemplating going that route, at least for the front.
    The other option would be to buy a set of bilsteins, and have them valved by a local shop, and put them together yourself.
    Also bilstein offers revalving and shortening of the rod.
    Expect to pay 70-150 for valving per shock, 50-80/per for shortening IIRC.
  1. Spring Rates for lowering
    By Nighthwk12 in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2013, 12:28 PM
  2. Broken Coil Spring. Advice on removal
    By TheInterloper in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2013, 08:34 AM
  3. Coilovers Vs Drop in Strut/Spring Combo
    By Max Cook in forum Brakes/Suspension/Chassis
    Last Post: 03-14-2013, 04:15 PM
  4. Spring rates
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 04-10-2011, 10:21 AM
