Thread: Caster Adjustment On Front End ?
Results 1 to 5 of 5
  1. #1 Caster Adjustment On Front End ?
    SE Level Member ZeroC's Avatar
    Chilliwack
    I Know its not really adjustable in the first place ...the car was in a minor hit on the passenger side ....alignment is perfect on all 3 corners but front driver side is giving me a caster of 4.0 degrees..max spec is 3.7 degrees
    already replace LCA just in case something went wonky
    alignment shop said they did adjust the cradle to get the passenger side in spec for caster
    any tips / tricks for me guys ?
    its a 99 gtp fyi
    thanks
  2. #2 Re: Caster Adjustment On Front End ?
    Caster will not affect tire wear, don't even worry about it.
  3. #3 Re: Caster Adjustment On Front End ?
    Chilliwack
    yeah i know this ...but everything was green but this on my alignment page ....i must fix it hahaha
  4. #4 Re: Caster Adjustment On Front End ?
    GT Level Member mkyota1's Avatar
    Daytona, florida
    You might have bent that strut if it was a pretty good hit.
  5. #5 Re: Caster Adjustment On Front End ?
    Pennsylvania, USA
    Something definitely got bent pretty good. Caster is just the angle of the steering axis, so go over anything related to steering. Struts and mounts, control arms, even where the arms bolt to the subframe. Subframe bushings would be good to look at too, and even though it's unlikely, inspect the steering knuckle as well. I can promise you something is bent.
  1. Dic date adjustment
    By raygt2005 in forum General Grand Prix Discussion
    Last Post: 12-08-2012, 10:25 AM
  2. valve adjustment
    By chevyman39452 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-23-2012, 02:56 PM
  3. BBV adjustment = +2psi !
    Last Post: 07-14-2009, 03:51 PM
  4. Headlight Adjustment
    By 97GP in forum General Tech Discussion
    Last Post: 08-17-2008, 11:28 PM
