Thread: How to tell the difference between bad CV shaft or wheel balance?
Results 1 to 8 of 8
  1. #1 How to tell the difference between bad CV shaft or wheel balance?
    Florida
    From 60 mph on up especially at 80, car gets this bad shaking. When cruising on highway its like every 3 seconds I feel it vibrate harder then calms then again 3 sec later in a pattern the whole time. Now my driver side CV boot is torn and has been for a bit and im wondering if thats the cause or do I just need a balance since I notice on 3 of my wheels there a weights missing but idk. Im taking a 3+ hr trip tom so just want to know what it could be out of those 2 so I can have a smooth ride.
  2. #2 Re: How to tell the difference between bad CV shaft or wheel balance?
    move the wheel to a different side/spot and feel for it.
    however, a torn boot is bad news bears all around.
  3. #3 Re: How to tell the difference between bad CV shaft or wheel balance?
    Donating Users
    Aug 2013
    Michigan, USA
    Cheaper to get the wheel balanced. Go to a tire service if you don't have your own balancing machine and have them do balance and rotate tires. If it still vibrates, replace the shaft. You'd need to replace the shaft eventually because contaminant gets in and eventually ruins the parts. You'll know it's about gone when it makes loud clicking noise while driving.
  4. #4 Re: How to tell the difference between bad CV shaft or wheel balance?
    Florida
    Yea i have no noise just bad high speed shake/vibrate. Plus need an alignment lol.
  5. #5 Re: How to tell the difference between bad CV shaft or wheel balance?
    ....you "need" an alignment and you're talking about vibration? c'mon, man....
  6. #6 Re: How to tell the difference between bad CV shaft or wheel balance?
    04 Comp G.
  7. #7 Re: How to tell the difference between bad CV shaft or wheel balance?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Balance the wheel because it obviously needs it if the weights are missing. Your CV also should be replaced if the boot is torn. You could just replace the boot but depending on how many miles are on your car you may as well just replace the CV axle. If you do replace the axle get if from Napa. Everyone elses are too short and the boots have less ribs which makes them wear out and tear sooner.
    I went NA when a whore left -$300 in my bank account.
  8. #8 Re: How to tell the difference between bad CV shaft or wheel balance?
    Florida
    Just an update,turns out i just needed my wheels rebalanced along with alignment took a run up to 100mph and not a single jiggle or shake. Rides like butta.
  1. should i get rid of my balance shaft gear with a vs cam?
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2013, 02:56 PM
  2. Balance Shaft Removal
    By btamayo in forum General Tech Discussion
    Last Post: 03-04-2011, 07:15 AM
  3. how do i remove the balance shaft
    By copperpacecar in forum General Tech Discussion
    Last Post: 10-07-2010, 12:59 PM
  4. balance shaft removal PLZ HELP
    By bigdawg15005 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2009, 11:58 AM
  5. Balance Shaft
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2008, 10:42 PM
