Thread: "wrong" struts wanted for front of 97GTP to raise it..
Results 1 to 13 of 13
  1. #1 "wrong" struts wanted for front of 97GTP to raise it..
    Feb 2009
    flintnasty MI
    DONT ask why, but for some reason at the grand prix meet/show this year, there was a grand prix there that had installed the "wrong" struts for the front of his car that ended up raising it almost 2 inches.... I need to rebuild the rear of my GTP and for the stupid offroading I plan on doing with it I would just install these struts in the front, then raise the rear via rebuilding the rear strut towers....
    Any help would be appreciated.
  2. #2 Re: "wrong" struts wanted for front of 97GTP to raise it..
    GTP Level Member
    Pittsburgh
    ya that GP was crazy.
    Over in the Bonneville world, the Monroe Quick Struts have been found to have 1-2 extra coils and will raise front of the car. Im assuming that its the case with the GP's also
    2003 SSEi,
  3. #3 Re: "wrong" struts wanted for front of 97GTP to raise it..
  4. #4 Re: "wrong" struts wanted for front of 97GTP to raise it..
    Feb 2009
    flintnasty MI
    I did and he didnt know why it was like that. He said he just changed struts didnt mention springs.
    I did a bit of eyeball measuring of the 04 struts and I see that the spring perch is visually higher up on the strut body compared to the 97 style....
  5. #5 Re: "wrong" struts wanted for front of 97GTP to raise it..
    I have my old comp g struts laying in the garage still if you think they will raise it.
  6. #6 Re: "wrong" struts wanted for front of 97GTP to raise it..
    Feb 2009
    flintnasty MI
    Could you measure from the top knuckle bolt to the spring perch?
  7. #7 Re: "wrong" struts wanted for front of 97GTP to raise it..
    Is that the measurement you wanted?
  8. #8 Re: "wrong" struts wanted for front of 97GTP to raise it..
    Feb 2009
    flintnasty MI
    should be good for me,thanks
  9. #9 Re: "wrong" struts wanted for front of 97GTP to raise it..
    no problem let me know if you need any other measurements.
  10. #10 Re: "wrong" struts wanted for front of 97GTP to raise it..
    Dan.. your wife called.. holy crap you need to clean again.
  11. #11 Re: "wrong" struts wanted for front of 97GTP to raise it..
    Feb 2009
    flintnasty MI
    Measured my 97 coil and strut... the top bolt to base of strut is about 8.5 inches. Yussss...
  12. #12 Re: "wrong" struts wanted for front of 97GTP to raise it..
    Feb 2009
    flintnasty MI
    Going to pick up my 04+ struts today. Weld bombing of rear suspension strut mounts begins soon. Going to cut out whats left of the strut mount I have, then build a 3 inch box on top of it, then weld it back into the car... 3 inch lift.
    Front end should just happen when the new struts go in, I cant find anything that looks wrong about them other than the extreme length. Only major fear is not being able to align it with enough negitive camber, but I could round out the mounting holes if needed.
  13. #13 Re: "wrong" struts wanted for front of 97GTP to raise it..
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    any updates on this? Possibly pics
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  1. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  2. Front Driver Side "Clunk" Mystery. Any ideas?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 05-10-2011, 03:41 PM
  3. "The whistle's go WOO WOO" on my 04 GT1, what's wrong with it? (video)
    By iroczkidtpi in forum General Tech Discussion
    Last Post: 06-25-2009, 04:44 PM
