Thread: CV boot clamp breaks off...sits to low to frame
Results 1 to 5 of 5
  1. #1 CV boot clamp breaks off...sits to low to frame
    omaha, ne
    I have a 97' GP GT and the passenger cv clamp keeps breakin off because it hits the frame. I have replaced control arm with new ball joint and tie rods. I have also replaced bottom motor mount and top 2 engine stabilizers and it still breaks off. Can anyone help me out and tell me what I am missing?
  2. #2 Re: CV boot clamp breaks off...sits to low to frame
    Portland Oregon
    Can you post a pic? This shouldn't happen.
  3. #3 Re: CV boot clamp breaks off...sits to low to frame
    Aug 2013
    California
    I am having the same problem with my CV boot clamp. What was your solution 2 years ago??
  4. #4 Re: CV boot clamp breaks off...sits to low to frame
    SE Level Member chuckbattams's Avatar
    BRANTFORD, ONTARIO
    Well gchans007 ... on mine it was the bottom engine mount, mine was passenger side. Big pain in the behind doing the change, in fact the first mount I bought was slightly smaller, but I put it in anyways, it worked, but the clamp was just missing the frame. After a bit, it started hitting again, so went to wreckers and got one off of them, now fixed!!! Still had a bit of a clunk, turned out to be the wrong CV axle, I accidentally got one off a 98 GTP, and it's about 2 inches or so shorter then the 97 GTP I drive... go figure! ENjoy Your ride..
  5. #5 Re: CV boot clamp breaks off...sits to low to frame
    Aug 2013
    California
    For the difference was the brace that connected the lower mount to the engine. Mine lost two bolts. Should have four. The brace is u shaped. Got the new bolts at hardware store
  1. hub/bearings/breaks?? Help Please
    By jayson14 in forum General Tech Discussion
    Last Post: 04-10-2011, 05:52 PM
  2. Exhaust band clamp for speed daddy cross over
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 04:01 PM
  3. Exhaust clamp size (Speed Daddy headers)
    By 2001GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2010, 07:06 PM
  4. car wont start after sits for 30 minutes
    By paul95 in forum General Tech Discussion
    Last Post: 04-17-2009, 04:32 PM
  5. Less Breaks at work???
    By offroadfury6 in forum The Rant Forum
    Last Post: 10-30-2008, 06:16 AM
