Thread: gxp brakes
Results 1 to 8 of 8
  1. #1 gxp brakes
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    What's a good price for gxp brakes. Looking to buy some but not sure what they're worth and don't want to way over pay for them. Tried searching but couldn't find anything with a price.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: gxp brakes
    GTP Level Member
    Pittsburgh
    I think I paid 300 for the front and rear calipers and brackets
    2003 SSEi,
  3. #3 Re: gxp brakes
    Get brakes from a Buick Allure "Lacross Super", they are the same size as the GXP's, just not drilled and slotted. Which IMO is better, because over time rust builds up in the holes and can make squealing noise's.
  4. #4 Re: gxp brakes
    GT Level Member mkyota1's Avatar
    Daytona, florida
    When I was looking I found the Bonneville GXP rotors were the same size and not drilled. They were also a lot cheaper than the buick ones. They are slightly higher than the GP GXP. Prices based on what I found at autozone and advance auto, you may find something cheaper.
  5. #5 Re: gxp brakes
    Arizona
    Gxp rotors are cast with holes not drilled and if anything the opposite of squealing will happen. That all depends on what pad you run.
  6. #6 Re: gxp brakes
    Buffalo, NY
    Guess I should have been a little more clear. I was talking about the calipers for front and rear. I was thinking along the lines of $300 as well so that's a good price. Trying to get me a set of them used.
  7. #7 Re: gxp brakes
    Arizona
    You can get gp Gxp front left and right rotors for 137shipped with pads
  8. #8 Re: gxp brakes
    Buffalo, NY
    *edit* nevermind thought the 137 for the calipers then i re-read and saw rotors.
  1. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  2. 04 brakes
    By anarchy in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2012, 07:31 PM
  3. Brakes on 99 GT and on 04 GT
    By Ksirb in forum Brakes/Suspension/Chassis
    Last Post: 10-23-2012, 11:10 PM
  4. Brakes squealing even after foot is off brakes
    By GTLGDP in forum General Tech Discussion
    Last Post: 06-26-2012, 09:16 PM
