Thread: Power steering pump or bad rack and pinon?
Results 1 to 11 of 11
  1. #1 Power steering pump or bad rack and pinon?
    Jan 2012
    FT Campbell, KY
    I really don't want this whining to be a bad rack and pinon unit, so I'm hoping that the noise that's identical to a bad hydraulic pump really is a bad hydraulic pump. How can I tell for sure? When the RPMs drop, the steering gets more and more difficult. Steering gets easier with even idle speed (no s*, right?), but it also gets easier as the RPMs come up off of idle. All of this indicate bad pump to me, but I'd like yalls input. Thanks!
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  2. #2 Re: Power steering pump or bad rack and pinon?
    Grand Rapids, MI
    Whining noise is the pump. Have you checked fluid levels?
  3. #3 Re: Power steering pump or bad rack and pinon?
    Jan 2012
    FT Campbell, KY
    I have, indeed. The last time I checked hydraulic fluid was about 3-4 days ago. It was a tad bit low, but I also know how particular these cars can be with low fluid so I brought it up to JUUUUUUUST a bit over full.
    Colleen
  4. #4 Re: Power steering pump or bad rack and pinon?
    Grand Rapids, MI
    I'd replace the pump. If it has fluid and still whines and you're steering is stiff or agitates. They aren't that expensive, they're easy to do.
  5. #5 Re: Power steering pump or bad rack and pinon?
    Jan 2012
    FT Campbell, KY
    Do you have your finger on the pulse of who I should be sourcing these parts from? I'm talking like Duralast or Federal-Mogul. Worry not, I will NOT use anything house brand on my cars. I see that ZZP has a unit for $45. Lol, of course, they also have the $330 electric pump, but my account and wife both say STFU on that.
    Colleen
  6. #6 Re: Power steering pump or bad rack and pinon?
    Grand Rapids, MI
    Quote Originally Posted by ricksgpgtcolleen View Post
    What century are you from?? lol
    Um I bought a reman a-1 cardone pump from rockauto and it was absolute junk. I bought one from Ed Morad and it worked like a dream. Not sure on a new/reman brand worth buying
  7. #7 Re: Power steering pump or bad rack and pinon?
    Jan 2012
    FT Campbell, KY
    Forsooth, young man, what ever could you mean? LOL
    The one you got from Morad, was it a used one or does he dabble in the new stuff now?
    Colleen
  8. #8 Re: Power steering pump or bad rack and pinon?
    HUDSON
    Get a good OEM original pump if at all possible, the 2 "DURALAST" pumps from Autozone I have installed on my car have been junk, and I wish I had kept my factory pump and just installed new seals and orings.
  9. #9 Re: Power steering pump or bad rack and pinon?
    Jan 2012
    FT Campbell, KY
    Are the seals the only reason that these pumps go bad? Are there internals that tend to lunch themselves? How much of a PITA is it to rebuild the pump on my own?
    Colleen
  10. #10 Re: Power steering pump or bad rack and pinon?
    Grand Rapids, MI
    The one from morad are used but they test their parts. And if it is bad they replace it without hassle.
    And if I didn't go Morad route... I would get one of the delco pumps from Rockauto either the reman or the new one. Not sure how the delco reman is compared to duralast or some crap though.
  11. #11 Re: Power steering pump or bad rack and pinon?
    im using a duralast p/s pump, for the last 2 years now, it makes not a sound wheel turns like butter at idle in park.
  1. Power Steering Rack
    By djb in forum 5.3L V8 (LS4)
    Last Post: 07-06-2012, 09:13 PM
  2. Rear knock sensor / power steering pump / rack & pinion question
    By miwalter928 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 09:38 AM
  3. Most inexpensive rout to rack and pinon replacement?
    By Jbruce308 in forum General Grand Prix Discussion
    Last Post: 03-30-2012, 02:13 PM
  4. Sportiest power steering rack
    By BillBoost37 in forum General Tech Discussion
    Last Post: 01-11-2011, 06:36 PM
  5. Power Steering Rack replacement 98 GT
    By Fritcr in forum General Tech Discussion
    Last Post: 04-27-2008, 06:03 PM
