Thread: Subframe bushing removal? Help....
Results 1 to 7 of 7
  1. #1 Subframe bushing removal? Help....
    Donating Users Mr D's Avatar
    Nov 2011
    Chicago
    03 GTP, 138k mi. So I ordered a mint in parts, and a few tools to make it happen. I am working on replacing my transmission shift solenoids, and thought my chronic vibration might be due to worn subframe bushings, so plan to replace them while the subframe was lowered. But.....now that I have the car tore apart, and all the parts in hand, and can see what I'm dealing with, I can't imagine how to get the subframe bushings out. They seem to be fused in, my slide hammer blind pulley puller doesn't fit, and I do NOT have pneumatic tools.... Seeking suggestions, tips, lessons learned, et al. Thanks
    The problem that's causing the issue is right there between the seat and steering wheel. It's you
  2. #2 Re: Subframe bushing removal? Help....
    From the factory they are simply pushed together by hand. Typically they rust in a bit over time. I've used an air hammer to loosen and get them out.
  3. #3 Re: Subframe bushing removal? Help....
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Agreed! They tend to not want to come out after not moving for 10 or more years.
    I recently dropped my subframe for a cam install, thankfully the pass. side that I needed loosened the most was fairly co operative but the driver side bushings what a PITA! They screeched like nails on a chalkboard every time they budged a little.
  4. #4 Re: Subframe bushing removal? Help....
    I live here. DirtDog's Avatar
    Jun 2012
    Impact gun = best friend
  5. #5 Re: Subframe bushing removal? Help....
    Quote Originally Posted by DirtDog View Post
    Impact gun is for removing bolts.. air hammer is for whackin stuff free
  6. #6 Re: Subframe bushing removal? Help....
    Arizona
    Prybar and hammer
  7. #7 Re: Subframe bushing removal? Help....
    Jun 2012
    I stand corrected.
  1. sway bar bushing help
    By kking89 in forum General Tech Discussion
    Last Post: 07-29-2013, 04:45 PM
  2. Dorman Subframe Bushing any good?
    By Mr D in forum Brakes/Suspension/Chassis
    Last Post: 06-19-2013, 08:27 PM
  3. Is this bushing Dead?
    By jxmetal in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2011, 09:56 AM
  4. Control Arm Bushing
    By VGPGT in forum Brakes/Suspension/Chassis
    Last Post: 06-11-2009, 03:56 PM
  5. Bushing
    By JCG's-GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-09-2009, 02:31 AM
