Thread: [pro-active maint] when would a brake caliper need to be replaced?
Results 1 to 8 of 8
  1. #1 [pro-active maint] when would a brake caliper need to be replaced?
    May 2013
    detroit
    03 GP GT w/ ~165k
    friend helped me with my brakes last week and noticed that a significant amount of force had to be applied with c-clamp (or whatever the tool is) to pry-open the caliper so we could install it back over the new pads.
    this was the only caliper that gave us any issues or major resistance.
    under what circumstances would it be beneficial to replace the caliper?
    they are not expensive for used replacement parts, but just curious if it is an issue at all and what type of failure to expect if something did happen.
  2. #2 Re: [pro-active maint] when would a brake caliper need to be replaced?
    they can get rusted or corrode and not go back in smooth, as long as it dont hang up after you let off the brakes it should be ok. if its a front brake you'll feel the car pull to that side if it not backing off the rotor.
  3. #3 Re: [pro-active maint] when would a brake caliper need to be replaced?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Did you have the brake fluid cap open while doing this?
  4. #4 Re: [pro-active maint] when would a brake caliper need to be replaced?
    Some things to consider,
    The master cylinder cap
    The hose feeding the caliper (often these hoses start to come apart inside and work like a check valve. Hoses are cheap.
  5. #5 Re: [pro-active maint] when would a brake caliper need to be replaced?
    I live here. TLSheff's Avatar
    Upgrade to 12" rotors with F-body calipers and call it a day.
  6. #6 Re: [pro-active maint] when would a brake caliper need to be replaced?
    May 2013
    detroit
    no issues at all as of this time. that's why i was curious about pro-actively replacing it and just "what happens" if/when it fails.
    if i start to feel a little pulling, then i could quickly replace ... but my question was more along the lines of how likely would it be to have the caliper seize up (thus not being able to drive/move the vehicle). if it is high risk of seizing, i will replace immediately. if it is low risk and may notice some "pulling" if (when) it does start to fail, then i would have time to replace it then.
    is there any reason not to purchase a tested/used caliper from morad parts? or should it be a new caliper.
  7. #7 Re: [pro-active maint] when would a brake caliper need to be replaced?
    if you feel the need, used is fine to use. new is ok as well, or reman.
    yours can be rebuilt very easily as well. search you tube, lots of vids how to do it.
  8. #8 Re: [pro-active maint] when would a brake caliper need to be replaced?
    May 2013
    detroit
    ordered a used to replace. i prefer pro-active route, as it's an easy job and the brakes are fresh. thanks for all the input.
  1. Brake caliper slide pin?
    By Fahrenheit in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2012, 12:21 PM
  2. Painting brake caliper
    By IAMABANANA MOOO in forum Visual/Body Modifications
    Last Post: 08-01-2012, 05:00 AM
  3. Brake Caliper to Hub bolt
    By GPGT4dr in forum Brakes/Suspension/Chassis
    Last Post: 02-24-2012, 03:57 AM
  4. brake caliper question
    By mk frilla in forum Visual/Body Modifications
    Last Post: 12-13-2010, 02:14 AM
  5. Brake Caliper check...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2008, 10:58 PM
