Thread: Outer CV Joint Boot
Results 1 to 2 of 2
  1. #1 Outer CV Joint Boot
    Sep 2012
    Cedar Rapids, Iowa
    The little metal ring that tightens the end of the outer boot on the CV Axle snapped on my car leavin my wheel well and wheel along with everything else back there coated in grease. Before I replace that metal band should I add skme more grease to the inside of that boot? And if so what kind of grease should i use?
  2. #2 Re: Outer CV Joint Boot
    I forget what kind, hit the parts store and they'll usually have the packet of goo
  1. Outer Tie Rod
    By CDooley in forum General Tech Discussion
    Last Post: 05-15-2012, 08:51 PM
  2. Outer Tie Rod Nut Siezed
    By zeppelin913 in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2011, 04:58 PM
  3. wondering about outer tie rod
    By fremmy182 in forum General Tech Discussion
    Last Post: 09-18-2010, 02:30 PM
  4. Tie Rod Replacement Inner and Outer
    By mainecrab in forum Brakes/Suspension/Chassis
    Last Post: 07-09-2010, 10:31 PM
  5. Ball Joint Boot
    By JJ91284 in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2008, 11:17 PM
