Thread: front brake line question
Results 1 to 3 of 3
  1. #1 front brake line question
    St. Louis
    Upgrading soon to the 06+ Monte/Imp front brakes and need to replaced the front lines. I can't find a definitve answer on this so here goes. Do I need to buy the lines for the 06+ monte or just the stock lines for the GP? I know I need to bend the tab out so they are long enough and to check for tire clearance. Don't really feel the need to drop the $$ on SS lines at this time.
    I also have the banjo bolt that came with the new calipers (saved everything minus the lines from the JY). Do I need to replace that or can I reuse it?
  2. #2 Re: front brake line question
    I live here. DirtDog's Avatar
    Jun 2012
    U can reuse the lines as long as their long enough. And the gp lines should work...again as long as their long enough
  3. #3 Re: front brake line question
    St. Louis
    Thanks. I *thought* they would fit since the Imp is a W-body too, but we know how little things change from year to year. I would reuse my existing lines, but seeing as how I have to break one end loose anyway, might as well get fresh ones on there. That and I'm not 100% sure but suspect that they are the original lines. At 295,000mi. might just be time to change em out for safetys sake.
    Big a** brakes won't do me much good if the lines burst, lol....
  1. Replacing brake line - ABS module to right front wheel
    By SPECIAL EDITION in forum General Tech Discussion
    Last Post: 10-31-2011, 03:51 PM
  2. ss front brake line
    By 04BlackComp_G in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2011, 03:08 AM
  3. Brake line question
    By frankjc in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2010, 07:19 PM
  4. Front to rear brake line replacement - need advice
    By bxfl in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2010, 09:56 AM
  5. Fbody brake line question
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 05-09-2009, 05:00 PM
